E46 (1999 - 2006)
Old 06-11-2017, 06:10 PM
muzz13 muzz13 is offline
Mein Auto: BMW E46 325i 2001
Help needed! stalling and rough idle 325i e46
Hey guys,
I have a 2001 325i e46 (automatic) and I'm having issues with it running.
the idle is extremely rough and often the revs die then pick back up then die and pick back up before eventually stalling (watch video below). It happens every morning and when the car has been sitting for a while during the day, when I'm applying the throttle it doesn't effect it. Its only when the engine is idling.
When i apply the break hard the idle also revs up and down before stalling which is dangerous and annoying because you loose you power steering and coming off the highway it isnt idle
I have recently tried a few things and i have listed them below:
- replace fuel filter
- replace plugs
- replace MAF sensor
- new air filter
- new intake throttle gasket
- check intake elbow for rips
- clean the idle control valve with carburettor cleaner
Initially i thought it was an air leak so with the engine running i push down on the elbow and the engine would stall and i found the actual intake throttle was loose of the engine believe it or not.
I tightened it thought that would be the issue fixed..... no go.
Its getting progressively worse to the point where it stalls at almost every intersection where i stop for more than 5 seconds until the car warms up then it seems to not be as bad.
I sprayed carburettor cleaner around the elbow and manifold and it didn't rev up at all so I'm assuming there is no leak there. Its almost like it may be a fuel issue? Because the car settles at about 600-800rpm before diving repeatedly and returning to 600-800rpm before eventually dying.
I also replaced the fuel filter about 4 years ago with a cheap after market one so maybe it could be that?
I was just wondering if anyone has had the same issue and what they did to fix it as i am stumped. I have read maybe the DISA valve replacement?
Any direction would be much appreciated.
https://www.youtube.com/edit?o=U&video_id=Wr60W5OG4xU_a_
Old 06-13-2017, 06:41 AM
Not sure if my post is invisible or people genuinely have no clue what is going on with the car.... my thread seems to be the only one without a bloody reply.
Old 06-13-2017, 09:04 AM
justinhartl justinhartl is offline
Mein Auto: 2003 BMW 325i
It's not invisible lol, I've read it and honestly have no idea what that may be... I'd say get a diagnosis on it... good luck!!
Hey guys,
- replace plugs
- new air filter
Old 06-13-2017, 10:47 AM
lincolnshibuya lincolnshibuya is offline
Mein Auto: bmw 325xi
read this, everybody is busy fixing what's wrong with their BMW too
this and cooling system problems are too common that you can find a lot of resources on google and youtube.
http://forum.e46fanatics.com/showthread.php?t=897616
https://www.facebook.com/diybmwe46/
Old 06-16-2017, 08:43 PM
haha all good, thanks for the input. I'll let you know if i come up with an answer!
Old 06-17-2017, 05:04 AM
marcozandrini marcozandrini is offline
Mein Auto:
Your engine has vacuum leaks. Have the intake system smoke tested.
Old 06-17-2017, 09:19 AM
kirmanj kirmanj is offline
Mein Auto: Bmw
If you have cleaned the idle control valve, throttle body and replaced the plugs. The only main culprit would be a vacuum leak, possibly in the lower intake boot. If that's not it read the codes and if you find nothing then take it to the mechanic or dealership and get it diagnosed. You don't want to keep spending without a guaranteed fix.
Sent from my SM-N9005 using Bimmerfest mobile app
325i 2001 automatic, advice, air leak, e46 bmw, mechanical help, rough idle, stalling
