E46 (1999 - 2006)
Old 06-11-2017, 06:12 PM
M3angel2001 M3angel2001 is offline
Mein Auto: BMW e46 328i
328i 1999 My fan clutch stays engaged the whole entire time I drive
Ok it's my first time using this but I'm in big need of help I'm hoping some one can help so here goes nothing
I drive a 328i 1999 My fan clutch stays engaged the whole entire time I drive there's a few times it shuts off but other than that it's mostly on the other weird thing is that I've never seen my radiator fan turn on so I'm really out of things here ive replaces the fan clutch and fan but it continues to make like a vaccume noise when I drive I'm in need of help what can it be ?
Old 06-11-2017, 06:18 PM
Fan clutch engaged
Old 06-11-2017, 07:08 PM
eparayno's Avatar
eparayno eparayno is online now
Mein Auto: 2001 530i
It's a 3 year old thread and you're in the 5 series section....with that out of the way - what brand fan clutch did buy? If it's an aftermarket off the shelf one then I'd suspect it's the unit itself. Fan clutches are fully engaged at startup and in stop and go traffic only unless you might have a warm climate/heavy duty one.
Old 06-11-2017, 07:25 PM
tim330i's Avatar
tim330i tim330i is online now
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
Moved to our E46 3 Series forum.
Old 06-11-2017, 07:47 PM
It's a oem I won't ever use aftermarket parts I changed both clutch and fan but it just stays engaged the time I drive but my radiator fan doesn't turn on
Old 06-11-2017, 08:41 PM
crowz's Avatar
crowz crowz is offline
Mein Auto: '00 323i/97 528i/05 X5
Its supposed to stay engaged to some extent. It doesn't "stop" ever. The clutch lets the fan "free wheel" to some extent but your never going to see it sit still with the motor running.
If its sounds like a jet engine then its "stuck" on. If you see it spinning but you don't hear it and the cars not overheating your in good shape in general.
On a real hot day leaving a parking lot you will hear it doing the jet engine noise. The hotter it gets the more it sets itself to the motors actual speed. So if its real hot outside it will make a bunch of noise as you rev up pulling out into traffic.
Old 06-11-2017, 08:43 PM
crowz's Avatar
The electric fan on the front of the radiator should turn on when you turn the air conditioner on. If the air conditioner is on and blowing cold air (aka it works too) then the electric fan on the front of the radiator should be on. If it isn't you have an issue with the electric fan.
Old 06-12-2017, 05:24 AM
Should I check the relay for the radiator fan ? And yea the jet noise is on the whole time I drive but I waste a lot of gas cause it's probably stuck on I'm thinking since the radiator fan doesn't turn on wouldn't that mean that the fan clutch would stay on ? Would it be better to convert it to an electric fan
Old 06-12-2017, 06:22 AM
crowz's Avatar
If its an automatic you need to stay with the mechanical fan. It just works better since the way bmw cools the auto trans the trans temps can spike with an electric only setup vs the mechanical.
A new fan clutch for my e46 was $40 or something when I replaced it from autozone last time. The one for my X5 was $80 that I just replaced.
The front fan diags can be found on the site here. Just use the search button.
Old 06-13-2017, 04:08 AM
marcozandrini marcozandrini is offline
Mein Auto:
Here's great info in the electric fan: https://drive.google.com/file/d/0B59...VlE/view?pli=1
Old 06-16-2017, 04:54 PM
Hey guys I need help my BMW continues to sound like a jet any idea what it might be ?
Old 06-16-2017, 06:22 PM
tim330i's Avatar
You have an automatic, right?
Old 06-16-2017, 07:58 PM
Yea
Old 06-16-2017, 09:17 PM
tim330i's Avatar
Can you turn the fan by hand when the engine is off?
Old 06-17-2017, 05:24 AM
It turns off with the engine it's a fan clutch
Old 06-17-2017, 09:22 AM
tim330i's Avatar
From your description it isn't working correctly, so it seems like a good place to start checking.
Old 06-17-2017, 07:10 PM
Well I replace the fan and the disc on where it sits on but it still dies the same thing
