Old 06-16-2017, 08:14 PM
laptop4079 laptop4079 is offline
Mein Auto: To many to list
cylinder 5 missfire help needed!
Hello everyone I'm still new here, this is my second post. This is my first boosted car and I've been bitten by the turbo bug. But sadly things are going to shambles. I misdiagnosed a bad idler pulley as the wastgates and she burns oil pretty bad but I'm working in it. The latest catastrophe comes after a small rumble with a sports bike. I was driving it the hardest yet and as I was slowing down my ses light came on and it started misfiring without warning. This is a constant misfire like it's not even trying to fire. I've pulled the codes with inpa but I can't read german and I've tried to translate it but it just didn't work. I'm going to pull the plug and swap the coil tomorrow to see what happens. I'm just worried if it's something worse.
Edit: I guess I don't have enough posts to add a picture
http://imgur.com/a/RyY1p
Old 06-16-2017, 09:11 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
Throw some more info up such as year, mileage, tune, etc. These are common issues with this car but reasons depend.
Old 06-16-2017, 09:16 PM
My bad! It's a 2007 coupe with 141k on the clock. Everything is bone stock afaik not sure how to tell if it's currently tuned or previously.
Old 06-16-2017, 10:01 PM
sptt144's Avatar
Lots of miles. Lots of possibilities. 2007 was not a good year for these. Assuming they had everything fixed under warranty it could just be a bad coil. You need to know which one is misfiring so you can swap the right coil. Don't do the plug until you test the coils. These coils fail often and just replacing the one should fix it. For me, it was always #1 (closest to radiator) or #6 (firewall where it gets much hotter). One other issue is the Valve Cover Gasket leak which sends oil into #3 and #4 causing misfires. You can see with the engine cover off if there is oil down in them or just by pulling the coils to see if they are wet. At 141k a new VCG is more than likely due.
Old 06-16-2017, 10:26 PM
The only paperwork I could find was from the hpfp at 4k. This is my newest bmw and I'm still learning how to sweet talk service advisers so I can get the rest of the history. I'm not new to bmw's and I do most of my own work. So far nothing looks too complicated Code reader says it's cyl 5. I'm going to swap the coil tomorrow. My brain always goes to the worse possible situation
Old 06-17-2017, 08:39 PM
sptt144's Avatar
Most of the issues I've had are simple fixes. Nothing complicated yet. I replaced my water pump (failed at 88k) and all my struts and shocks and even that wasn't that bad.
Sent from my SM-G935V using Bimmerfest mobile app
Old 06-18-2017, 02:33 PM
Success! It was the coil pack! I swapped cyl 5 and cyl 1 and the code moved to cyl1. I'm going to do plugs. Is it worth it to change all the coil packs? Some of them have chips on the sides. I'm going with bosch plugs and coils but they're not bmw branded to save some $$$ https://www.amazon.com/Piece-Bosch-S.../dp/B00804F080 https://www.amazon.com/Bosch-0221504...s_a_1_1&sr=8-1
Old 06-18-2017, 02:41 PM
CALWATERBOY DUE's Avatar
CALWATERBOY DUE CALWATERBOY DUE is offline
Reregistered User
Mein Auto: 09 E93 335i somewhat mod
Messrs. Page & Brin to the rescue....
Or [this] and pay attention to the misfire diagnosis link.
Old 06-18-2017, 06:54 PM
gordo325xiwagon's Avatar
gordo325xiwagon gordo325xiwagon is offline
Urban Knucklebuster
Mein Auto: '01 325xit & '93 300zx TT
Yes, change all the coils. Keep the good used ones for backup, but change them all out. My 2012 had only 30k and two were bad. They are a known defect in later model three series.
__________________________________________________ ___
2001 325xit & 2012 328i Sportwagon - Evolution of the Brand
