E46 (1999 - 2006)
Old 06-17-2017, 11:14 AM
Bimtec Bimtec is offline
Mein Auto: 2001 BMW 330ci
BMW 330 ci convertible
As all know issues with BMW's are guaranteed, despite new car price increases and 5.1 % sales growth.
I'm still trying to resolve a battery drain issue, a water in the trunk issue, and the reverse shift clunk issue, I'm getting closer to find the problem with the battery drain which might be a aftermarket radio connection to an iPod hook up cable, when the fuse is pulled for the radio it's seems to show less amp draw, I'm still investigating.
I ordered the rear axle bushing recommended to me and waiting for it to arrive from slowsky shipping. After I get it installed I will let y'all know if it eliminated the clinch. Happy Father's Day to all you Mothers out there.
Old 06-19-2017, 11:12 AM
Tanning machine's Avatar
Tanning machine Tanning machine is offline
Using SPF 45
Mein Auto: 2004 330Cic
On battery drain, did you ever have the dealer recode the AC so that it wouldn't drain the battery after you shut off the car? That was a known problem for some earlier E46s that hit me - basically if you turned off car with AC running, sometimes a fan would keep running and running, and the battery would be dead by morning. Happened to me once, and got it fixed.
Tanning Machine I: 1989 325iC (Salmon Silver/Black, Heated Seats, LSD). 7/26/1989-11/1/2003.
Tanning Machine II: 2004 330Cic (Silver Gray/Natural Brown, SP, PP, Heated Seats, Xenons). 8/29/2003-present.
Old 06-19-2017, 11:29 AM
cityjohn's Avatar
cityjohn cityjohn is offline
Mein Auto: 1998 M3 . . . 2012 528i
^ just saw your username. I remember those ads!
and good luck OP getting everything resolved
Old 06-19-2017, 12:04 PM
Hey tanning, and I have a 2001 BMW 330 CI convertible and the air conditioning does not have an on off switch basically it turns on When you start the car and shuts off when you turn the car off.there's nothing on when I checked the battery and it was drawing .01 amps and in several days it was dead i'm still working on the problem I'll keep you posted as to what resolve the situation thank you for your advice
