Old 04-14-2015, 10:59 AM
fiveseven fiveseven is offline
Mein Auto: E39 530i 2001
Hi,
After leaving the car for the whole night with the dipstick taken out I could read the level pretty well. It was low and that's why I wrote that I cannot see any improvement in the oil consumption after installing OCT+PCV.
I've tried to smell gas in the oil but there was no evident smell.
After ~7k miles the oil is still transparent but for sure darker then the fresh one.
I'm changing my oil this summer so I will replace the sensor at the same time.
Thanks.
Old 04-17-2015, 03:12 PM
dbarton62 dbarton62 is offline
Mein Auto: 04 Z4 3.0 S/C 6 speed
So I did the described catch can PCV mod over the winter and the vacuum it pulls is amazing.
My valve cover bolts had to be snugged down to stop vacuum leak I could hear once the engine was shut down, which I could never hear before.
Word of warning make sure the PCV valve itself is facing the right direction. Ask me how I know.
Threads towards the IM.
Old 06-03-2015, 06:35 PM
flyride flyride is offline
Mein Auto: 530i, 330i, M3
Nice install.
Old 06-09-2015, 11:51 AM
There is a unique thread today on temporarily BYPASSING the CCV, for reasons that are up to the owner, but one of which can be to TEST whether the smoke or other symptoms are due to the CCV:
> E39 (1997 - 2003) > PCV Crankcase Vent Valve Temporary Installations
Originally Posted by Alika808 View Post
I installed the PCV temporary within 1 hour. You need to replace the tubing (item #2, item #3 and item #4) with longer hoses but use the end of each tubes that came with it. This is only temporary until you have enough time to replace the PCV under the manifold. It cost me $10.00 for the hose replacement.
See also:
- How the CCV system works (1) & how the -CCV +PCV mod works (1) & how the -CCV +PCV +CATCHCAN mod works (1)
Old 06-13-2015, 03:28 PM
PrimeSuspect PrimeSuspect is online now
Driving Dorethy
Mein Auto: 2001 530i
Is that a catch can? Yes it is. Goodbye CCV
I drained my catch can today and like some, I had more goop than I would have thought in just 3 months.
ID:	514298   Click image for larger version
Old 06-13-2015, 05:05 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
I would say thats normal. alot better than going back into your engine.
2003 X5 3.0i
Old 06-22-2015, 08:49 AM
Another non-aftermarket ccv-delete was proposed today for discussion.
> E39 (1997 - 2003) > OEM Solution to getting rid of the CCV? Kind of ingenious!
Originally Posted by BavarianE31 View Post
http://e46fanatics.com/forum/showthread.php?t=1066308
Basically replacing the M54 valve cover with a M56 one... Anyone think this would work? I'm not familiar with the problems (if any) that the M56 has relating to CCV issues (losing oil, mayo build up, etc) and whether the integrated CCV system is serviceable or not.
Thoughts?
Old 07-19-2015, 04:24 PM
FastFranky FastFranky is offline
Mein Auto: 530i, challenger, z28
Why not just relocate the factory POS CCV?
I spent quite a while reading through all 12 of these pages and and several other posts and forums without ever getting a warm fuzzy endorsement ( even form the sponsors - who have yet to devise a catch can kitt hat I can find ) on how this mimics the behavior of the factory valve. I spent a few hours or so removing all of the required parts to get to this valve. Then I thought, why not a hybrid approach to the catch can? Reuse all the factory connectors, and use 2 - 2 foot pieces of appropriate hose to go to the Valve cover breather and the intake manifold "T" then a 3rd 18 piece to drain back to the dipstick. By placing it just below the mounts in the inner fender ( next to the MAF - like most catch cans) sensor and running the hoses under the air intake the to the original locations) it's effectively at the same height as the original mount, uses the original BMW CCV ( actually cheaper than a catch can) and can be replaced in minutes. Has anyone else attempted this? I will ad pictures once I'm complete but I wanted to inquire if this has been done and whether I'm over looking anything.
Old 07-19-2015, 04:42 PM
I would like to see your set up when done.
2003 X5 3.0i
Old 08-06-2015, 06:55 AM
fmzip fmzip is offline
Mein Auto: 2001 530 / 2008 328xi
This is a sweet install! Curious as to which hoses you used and particularly the connectors at the valve cover and clamps that hold the two hoses connectors as they run across the intake. Any close ups of the OEM valve cover fitting to these black connectors?
PN's and links to all your pieces in this setup would be great! Nice Job!
Old 02-05-2016, 07:16 AM
Sroor9001 Sroor9001 is online now
ALGhoul
Mein Auto: Bmw 525i 2002
So friend how is the setup. And what's part number for this catch can and is the valve ok ??
Old 02-06-2016, 02:15 AM
ALGhoul
Originally Posted by eparayno View Post
Everything is buttoned up. New problem now though. During idle the hose I have going from the PCV to the intake is compressing, the hose becomes almost flat. Is it the valve or the hose? Maybe the valve is on backwards? I have it setup like how it is on the 1.8T engine but that application is forced induction.
And did you change the valve by another ??
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
