Daytime Instrument Cluster at Night - Page 5 - Bimmerfest - BMW Forums
Old 02-15-2017, 07:18 AM
KL4K50N KL4K50N is offline
Mein Auto: F10 525d
Originally Posted by joemulder View Post
I have a new used 2014 F10. with 6WA Instrument Cluster W. Extended Contents.
Could you please confirm if I can apply the code to change night orange to all white all time?
Is there any other factor that stopping me from coding this change?
Does firmware version matter? How do I find out the firmware version?
Thanks!
Sure You can do that Few minutes before i did update SW in my Instrument Cluster because i couldnt change color from orange to grey. With E-sys know i can code everything i want
Old 02-21-2017, 12:09 AM
gabytro05 gabytro05 is offline
Mein Auto: BMW F10
Does it work on 6wb? thanks
Old 02-21-2017, 04:12 AM
Almaretto's Avatar
Almaretto Almaretto is offline
Moderator
Mein Auto: Coded 2016 F10/ F15 Sport
Not that I have seen.
Old 05-23-2017, 05:45 PM
Bmwx5m50d Bmwx5m50d is offline
Mein Auto: X5
Hi where and how do I change these codes to make the cluster stay white?
Old 05-24-2017, 08:57 AM
Mein Auto: F10 525d
Hello
http://www.bimmerfest.com/forums/arc.../t-662851.html
Old 07-07-2017, 12:09 AM
dany81ta dany81ta is offline
Mein Auto: bmw f30
Originally Posted by ruben_17non View Post
you can code RLS by sensor for day/night mode. But originally only use tacho sensor for kombi and NAV.
I try only remplace photosensor by fixed resistance and work now. Allways white
Attachment 535339
The unique problem is, dim function not work.
I check if this is possible fix by code.
Hi .. how i can code it?? Or change resistor?? I have f30 2012.. now i change orange led with white led and i want day light in lcd.. very thanks!!
Inviato dal mio SM-G930F utilizzando Tapatalk
Old 07-08-2017, 01:50 PM
Mein Auto: bmw f30
This is rdl sensor of my f30.. how i fix it?? Thanks
