I've searched through the various thread s for this issue w/no luck.
When in guidance on the nav system how can I display next couple of directions. For example, the map shows location & direction and the dashboard (center between speedometer & teach) shows the next turn/exit etc. But I'd like to know the next two or three turns/exits like I can do on my Garmin. There must be a way to display this.
Push the iDrive controller to the left 2 times from the main Nav view, and select "Route Information". This will show the rest of the route and mileage for each segment. I don't think it shows the turn direction, but it will show you the route. I believe you can select a route segment and change it as well, but I have not done that.
I find that the easiest way to do it is by voice command. While in guidance mode, just push the voice command button the steering wheel and say route information. After you are done, just say map.
I use one of my programmable memory buttons to bring up the turn by turn directions easily and quickly as I find them more helpful that relying on the map at times. I also use it to review a new route to get a specific idea of where it is taking me, among other things. Just looking at the map overview sometimes just isn't enough AFAIC.
Position your iDrive controller on the instruction/screen you want, press and hold your selected memory button.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
