Does anyone here have any experience with the Centric brand brake rotors? Looks like they are out of California.
I have those PosiQuiet pads on my car now and, yes, they were super noisy when they were new. Since I've run them in, they've quieted down a good bit, but they still squeel like a scalded pig in reverse if they are wet. I really enjoy the lack of dust, but once my rotors are done, I'm switching to Akebono.I purchased the Centric Power Slot rotors, and the Centric Posi Quiet Ceramic pads. It's a disaster, and I don't know which is the culprit. The brakes are so noisy. They have always been noisy in cold weather, and even more so lately when the car has sit in wet weather. For some reason, most of the noise is always in reverse, like backing out of the drive way, or out of a parking space. Recently, normal braking while the car is in a forward motion, does not feel smooth.
The setup was not cheap, so I don't want to replace rotors and pads again, when I just did so last year, and have like 40,000 miles left on them. The rotors look in ok condition. There is some rusting look in the slots, but the surface looks and feels fine. Maybe the rust from the slots is trasferring to the pads. Any ideas. Not sure how I should move forward?
Great post and mostly true in my case as I didn't replace my rotors since they only had about 5k miles on them. I made sure i greased every point of movement I could which explains the lack of noise going forward. They only squeal if the pads are wet going in reverse (like after washing the car)..once dry they are perfectly quiet.Noisy brakes are almost 95% installation. Were the brakes thoroughly greased? Are the caliper slide pins greased or otherwise working properly? Etc.
Then bed-in and whether or not they were installed on used rotors, which sometimes the grooves on the new rotors and the surface on the fresh brake pads create harmonics.
I've used centric rotors several times with outstanding results. In many worlds, they are considered an outstanding OE-style rotor. It is very rare for rotors to warp under normal driving conditions. If they are off-set to the hub, if the wheel lugnuts are way over-torqued, or if the calipers are not evenly applying the brake pad....those things will all warp a rotor quickly....and yet the rotor will often get the blame as crap.
Just to be clear, I've used cheap chinese $25 rotors that don't warp when installed properly, with good hub centricity, working calipers, and torqued lug nuts. Centric is far from a cheap chinese rotor.At the very least, they are an appropriately priced chinese rotor
