I have a 1999 528i with a M52TU engine which I need to replace the Vibration Damper on the crankshaft. I ordered the special tools 11 8 190, 11 8 200 and 11 8 210 to remove this damper and install a new one however my particular Vibration Damper has 6 screws holes and not three oval shaped slots to insert the special tool 11 8 200 into. The center hex bolt which is torqued down to the crankshaft has a flared out lip on it like a washer which holds the "outer" pulley to the vibration damper. (See picture.) How do I attached the special tools I have to keep the crankshaft from turning and remove this center bolt then remove the Vibration Damper? Help ASAP!!!
Looks like you have the two piece set-up (version 1) below...no mention of removing the centre bolt with this arrangement - could be stuck a waiting for a little encouragement.
it would appear that you have the older style damper which does not require any special tooling to remove. Just tap it with a rubber mallet or put a piece of wood over it and tap the wood with a hammer. It will come right off.
Thank you for your reply. I am still confused as the center bolt seems to be holding the pulleys on the crankshaft. When I try to remove this bolt, the crankshaft turns moving the pistons, flywheel, etc. There must be a way to secure it with a special tool or a plug to keep fly wheel from turning.. I have noticed a "plug" between the two bottom screw holes on the right (See new pic attached) ... However, there is a way to lock the flywheel from turning with the plug in back of the engine (going into the torque converter)... perhaps this is the manner to secure it?
you DO NOT need to remove the center bolt to remove the damper. Period. The center bolt holds a hub onto the end of the crank. The hub is what the 6 bolts thread into.
I see you added a pic to your original post. The arrow is the locating dowel, which stays in the hub.
Soak the thing in some PB blast and tap with a rubber mallet if you have to, it's just seized on there. The AC pulley AND the damper will come off, while the center nut stays.
The only time you need to remove the hub is for taking off the timing cover. They make a special tool which bolts on in place of the damper to hold the crank. That special tool is number 112150 but it is not needed for what you are doing.
I've had enough of these apart to know. You're making a big job out of nothing here.
see this? This is the same damper that is installed on your car. (back side pictured) I removed it by taking the 6 bolts out and tapping it a bit with a rubber mallet. Note the size of the hole in the middle is just big enough to clear that center bolt and ring.
ahh I see. Sorry I was close but not 100% on my info. The 98 I had done had a two piece pulley system. The AC pulley was sandwiched on top of the damper. Same overall thing though. Looking again I see your damper also does not have the same "bumps" on the outer edge as mine pictured. There were a lot of little changes between late 98 production and 99 production. It's hard to keep it all straight.
Glad to be of help though, and no, I am far from a genius. Just a case of been there, done that, got the Tshirt.
I am about to dive into the same job for my '99 528iT and have the same setup. My reason for doing so is to replace the front crank seal. I have two questions after reading this thread.
First is, will I need to dig deeper than this and with special tools to replace the seal?
Second is, how do I keep the crank from turning while loosening/tightening the six pulley bolts?
Thanks in advance,
Neil
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
