Hey guys! I had to the intake manifold in order to get to the water pipe leak which I have. As I inspect things the CCV has gjunk in it tubes going to the oil spout has is gunked too. I'm going to be replacing the CCV and the tubes as well as all the vacuum but I noticed that the valves had a lot of carbon buildup on the tops of them. What's the best way to clean these? Can I use throttle cleaner on top of the valves in the intake area to clean it up? Then use a small vacuum with the hose to suck out things in there? I don't want anything to get down in the engine however I hate leaving it dirty like that. Your thoughts??
I just removed my intake manifold yesterday to replace the heater inlet pipe and water pipe as well. This was my second time removing the mani - valves look spotless. I cleaned the manifold with throttle body cleaner and Brakleen non chlorinated. Used brushes to get gunk out of the ram tubes and runners. I also used Brakleen sprayed onto a rag to clean the slightly browned intake ports on the head but didn't touch the valves.
Btw, does the heater and water pipes need two Orings on them? There seems to be a place for two... One set inside the housing and the other in the channel of the end of the pipes. Also, I noticed a slight build up of white (cream colored) residue inside the pipes. I assume that this is through out the cooling system arteries. Is there anyway to clean this out throughout the engine ?
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
