Been wanting to do this for some time now. I have the Skaggs pedals and my dead pedal in the car.
I have 5/8 inch Delrin spacers in the front of the drivers seat. For me this works out fine with the seat back where I want it (a hair from all the way back). As you move the seat forward less of a spacer is necessary.
With the seat back where I want, the brake and gas pedal are fine. The clutch and dead pedal are too far away.
Been driving around with a 3/4 inch piece of plywood on the dead pedal and a 1/2 inch piece taped on the clutch pedal which is right for me. Amazing the difference this makes.
For the dead pedal, I'm making a 3/4 inch Delrin spacer to go between my dead pedal and the stock one. If this doesn't look right, I'll make a 15/16 inch thick aluminum one.
For the clutch pedal, I bent (heat gun) a piece of Delrin over the curved metal brake pedal. Clamped it to the pedal and scribed the stock pedal outline on to the Delrin piece. Scroll saw and sanding block resulted in the piece shown in the following pic. Will probably have the 1/2 inch thick one machined.
