I am getting a new F10 in the next couple of weeks build date of 7/12 (ship is on the way). Will I be able to use the current psdzdata out there to code or will I need to wait for the next files to be out there? This is a cool thing to be able to do to our BMWs. Individual BMW - you bet this is better!:thumbup:
Hmmm - I'm not sure exactly - I was just following posts earlier in the thread where you indicated that 47.4 was missing some files (from 47.1). I'm having issues accessing the CAS module in a 2013 F10 with 47.4. Beyond that, I'm kinda stuck. See below.
Originally Posted by shawnsheridan
Ok, good.
You actually have 47.1 on your car, and for some inexplicable reason, 47.4 did not contain 6 CAFD files that were in 47.1, so if you need the other 5, let me know.
Right Orphan Files (6) Size Modified
cafd_0000000f.caf.005_024_220 1,006,395 6/14/2012 8:28:02 AM
cafd_0000000f.caf.005_024_221 1,004,963 6/14/2012 8:08:18 AM
cafd_0000000f.caf.005_024_222 1,005,095 6/14/2012 8:00:04 AM
cafd_00000a3f.caf.005_001_008 142,521 6/14/2012 7:06:02 AM
cafd_00000794.caf.002_020_029 6,060,497 6/14/2012 7:05:54 AM
cafd_00000794.caf.004_122_077 6,468,403 6/14/2012 6:40:58 AM
Ok, good.
Shawn,
Thanks for that file - I copied it into my c:\ESysData\psdzdata\swe\cafd directory. I then tried to Read the Coding data for CAS and I received the following message:
cafd_0000000f-005_024_222 Fehler:
File for "cafd_0000000f-005_024_222" not found! [C012]
It looks like the file you sent me is the right one, so I'm not sure why I'm getting this error message? Any thoughts?
Shawn,
Thanks.
i am new here, and want to learn something about coding on F-Series.
but i dont find a link to the newest data files (v47.4 i think ?)
Can some one give me that?
i only got the v46.1 files for E-Series, and i though there are also newer files.
Same here, iam new and looking for the missing psdzdata files.
I already have E-Sys 3.18.4 and an ENET Cable.
I think the 47.4 files are the newest available for my F30 328i 9/2012 correct?
The F10 files should be the same as F20/F30 or is this wrong?
I'm also going to learn about coding. The threads here are very helpful.
I've got the E-Sys already and should have now the PSdZData-files.
Shawn, am i right that they are compatible with older versions in the car?
Because I had my car by the dealer before 2 weeks and they did a whole software update.
But I don't know which files I have to use now, because idon't know the version in my car. But if the new are compatible, then I would be really happy if you could also send me the DL links for the files.
Thank you very much and looking forward to have success with my try. ;-)
New PSdZData though will not allow FDL Coding of any new HU_CIC features, unless it is first used to flash the firmware of the HU_CIC ECU, a process not yet fully understood nor documented.
Premium is the way to go. $10/30 days and you can download all the files in a few hours. Also it has been stated already but with files of this size, you may risk the files not downloading properly (smaller file size, etc).
Related Threads
BimmerFest BMW Forum
11.4M posts
754.1K members
Since 2001
