Old 05-07-2017, 10:41 AM
sjpaul sjpaul is offline
Mein Auto: 320i ZSP/6MT & X3 28i
iDrive will not boot up
I've had an issue come up with my iDrive in my F30. The iDrive interface does not complete the boot-up process; it just stays frozen on the BMW splash screen. This lasts for about 2 minutes, then it tries to reboot itself - goes blank until the splash screen reappears. While this is happening, the radio continues to play on the last station I'd had on.
My car has HU_ENTRY. The problem has re-occurred after the car has been shut off for several hours. I have tried to re-boot using the mute button and eject button - it reboots but the boot process does not complete.
Any ideas??
Old 06-12-2017, 08:56 PM
masterov masterov is offline
Mein Auto: 2014 F30
does it look like this?
Old 06-12-2017, 09:22 PM
F10-N52 F10-N52 is offline
Mein Auto: F10 N52 RWD
press and hold the volume knob for about 30 seconds - this will reset the computer.
Old 06-13-2017, 08:22 AM
Mein Auto: 2014 F30
When it restarts, it stays in the same state.
Old 06-13-2017, 10:18 AM
are you still under warranty? Looks like you're gonna need a new computer.
Old 06-13-2017, 10:59 AM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
Based on what?
Old 06-13-2017, 02:11 PM
Mein Auto: 2014 F30
I am sure replacing a computer is the simplest, and the most expensive solution. When a computer doesn't boot up, it is usually a software problem, so I hope that may be there is a way to troubleshoot it, without swapping the entire combox (especially considering that we don't know for sure that it will solve the problem)
And no, I am not under warranty
Old 06-13-2017, 06:31 PM
masterov, that's what it looked like when I had this issue. I tried all the easy-diy solutions to no avail. I took it into the dealer and they diagnosed it as a failed combox. They replaced the combox and i was back in business. This occurred at about 51k miles, but was covered under my extended warranty.
Old 06-13-2017, 08:01 PM
Mein Auto: 2014 F30
Thanks SJPaul
Old 06-14-2017, 10:55 AM
Mein Auto: 2014 F30
SJPaul, it is interesting that this occurred at 51k miles for me as well. Almost as if it was programmed to do so What was the part number that they had to replace? Can you please look at your invoice / work log?
Did you recently get a notice from them about disabling / upgrading your "SOS" function? Did you respond to that?
Old 06-14-2017, 12:12 PM
BeemerGuy's Avatar
BeemerGuy BeemerGuy is offline
former motorcycle rider
Mein Auto: F06
My F06 iDrive was constantly rebooting, and a software reload fixed it. That would be a lot cheaper than replacing the module, if it is hardware. It's probably worth spending $150 for an hour of diagnostics...
F06 (ours)
E90 (hers)
Old 06-14-2017, 05:48 PM
bimmerbingo bimmerbingo is online now
Mein Auto: 2015 435i Coupe
This will work on the CIC (possibly CCC as well), but not on the NBT and newer iDrive systems. AFAIK, there's no way to reboot the NBT+ iDrive systems, short of firing up ESys and doing it from there.
2015 435i X-Drive M-Sport, Sapphire Black, MPPK, MPE, 20" M performance forged wheels style 624M
Old 06-14-2017, 05:50 PM
Wow, really?? That is pretty crazy!!
I did have the combox replaced when they had the switch from 2G for the BMW Assist functionality. So this failure was on the combox that they had just replaced, less than a year ago.
I will try to track down my invoice and post the part number.
Old 06-19-2017, 03:13 PM
Mein Auto: 2014 F30
I'll go to the dealer tomorrow. Will report after that.
