2001 BMW X5 with 100k miles. Only repairs done is fuel pump. Now, i have the oil and coolant leaks. I have taken it into a shop and they want to perform work with estimate including tax of $3,648. Is the actual amount going to be less or higher than estimate and how much more would raise a red flag? Any opinions welcomed!
The following is what would be done:
Check for oil leaks. - UPPER TIMING COVER X5 4.4
Labor $1,089.00
Parts: $180.06
Labor: $1,089.00
Job $1,269.06
1) Check for coolant leak, expansion tank leaking recommend replace all hoses.
Labor performed on this job: Parts required on this job:
Labor $297.00
Parts: $442.34
Labor: $297.00
Job $739.34
2) Replace CV boot, left front.
Labor $277.20
Parts: $81.50
Labor: $277.20
Job $358.70
3) Replace drive belts.
Labor $99.00
Parts: $95.80
Labor: $99.00
Job $194.80
4) Replace front strut arm bushings.
Labor $160.38
Parts: $129.75
Labor: $160.38
Job $290.13
5) Replace both flex disc front & rear drive shafts.
Labor $338.58
Parts: $293.71
Labor: $338.58
Job $632.29
Labor $1,089.00
Parts: $180.06
Labor: $1,089.00
Job $1,269.06
Labor $297.00
Parts: $442.34
Labor: $297.00
Job $739.34
Labor $277.20
Parts: $81.50
Labor: $277.20
Job $358.70
Labor $99.00
Parts: $95.80
Labor: $99.00
Job $194.80
Labor $160.38
Parts: $129.75
Labor: $160.38
Job $290.13
Labor $338.58
Parts: $293.71
Labor: $338.58
Job $632.29
