Old 10-09-2012, 06:35 PM
wjjklj's Avatar
wjjklj wjjklj is online now
Certified 7
Mein Auto: 2004 745i
Anti-Friction rubber coating?
I am replacing my water pump and the TIS instructions call for applying a anti-friction rubber coating to the coolant pipe on the back of the pump. I am attaching a picture. Any idea what this is? Is it basically a silicone sealant to allow the rubber pipe to slide into the pump or is it a gasket material? Thanks in advance.
Old 10-09-2012, 06:37 PM
wjjklj's Avatar
Certified 7
Pictures
ID:	345021   Click image for larger version
Old 10-09-2012, 07:13 PM
wjjklj's Avatar
Certified 7
Can I Use this?
Old 10-09-2012, 07:39 PM
theckj theckj is offline
Mein Auto: E65
Use glycerine, permatex gasket sealant or the BMW part - drei bond. Usually it is just something to make the gasket seal better. I use black permatex high temp.
Old 10-09-2012, 07:41 PM
Mein Auto: E65
Don't use grease!
Old 10-10-2012, 09:35 AM
wjjklj's Avatar
Certified 7
Thanks for the reply.
Old 10-10-2012, 12:26 PM
Khabar Khabar is offline
Mein Auto: 745i 2005
use water soluble lubricant. U do not to touch at least that thick pipe. i goes from back of water pump to engine block.
Old 10-10-2012, 02:07 PM
wjjklj's Avatar
Certified 7
I already have it put back on and I used the silicone grease shown above. I assumed the anti friction compound was just to make the rubber slick enough to slide into the engine block. Am I right or is it going to leak and I need permatex or something?
Old 10-10-2012, 02:12 PM
it is not going to leak as long rubber is intact on the pipe. it goes against block of the engine and back of water pump.
Old 10-10-2012, 02:24 PM
wjjklj's Avatar
Certified 7
Thanks for the quick response I was headed to the auto parts store and prepared to pull the water pump back off. The short larger tube was in great shape and the rubber looked brand new after cleaning it. It did have some crusty looking stuff around the flange when I took it out. I didn't know if that was gasket sealer or just crusty coolant?
Old 10-10-2012, 02:27 PM
Why did u change water pump?
Old 10-10-2012, 02:46 PM
wjjklj's Avatar
Certified 7
I replaced the alternator but because I already had the fan out I figured I would just replace the water pump and all hoses and belts. The car has 86k and it is recommended at 100k. Just preventative.
