Stomp Test Procedure
107K views 74 replies 18 participants last post by  e39s
#1 · (Edited)
There have been multiple requests on how to perform the stomp test on the E34. Here it is per the Bentley manual. (According to Bentley, this is for 1992-1995 models only)
1. Turn ignition key to position 2 (just before cranking the engine)
2. Fully depress the accelerator to the floor 5 times within 5 seconds
3. The check engine light (CEL) will stay on for 5 seconds, blink off, come on for 2.5 seconds, then go off for 2.5 seconds. At this point, the fault codes will begin to flash.
If more than one code has been detected, each code will be separated by a 2.5 second pause. Edit: Sometimes if there is more than one code stored, the computer will NOT advance to the next code after a brief pause like all the write-ups and procedures say, it continually repeated the same code. If this is the case, push the pedal 5x after each code to make it advance to the next code. When all fault codes have been displayed, there will be a 0.5 second flash and then the light will remain off. To read the codes again, turn the key off and then on again. Repeat the process above.
To erase the fault code memory, first make sure the fault code 1000 (short blink and then the light goes out for a long period) is present, then depress the throttle fully for at least 10 seconds. Repeat the stomp test to look for code 1444 (no faults stored).
Here is a decent video I found on you tube of someome doing the the procedure. The code on this video is 1221.
Here is a listing of the fault codes for our OBD I E34's:
1211 DME Control Unit
1215 Air Mass Sensor
1216 Throttle Potentiometer
1218 Output Stage, Group 1
1219 Output Stage, Group 2
1221 Oxygen Sensor 1
1212 Oxygen Sensor 2
1222 Lambda Control 1
1213 Lambda Control 2
1223 Coolant Temperature Sensor
1224 Intake Air Temperature Sensor
1225 Knock Sensor 1
1226 Knock Sensor 2
1227 Knock Sensor 3
1228 Knock Sensor 4
1231 Battery Voltage/DME Main Relay
1232 Throttle Idle Switch
1233 Throttle Wide Open Throttle Switch
1234 Speedometer A Signal
1237 A/C Compressor Cut Off
1242 A/C Compressor
1243 Crankshaft Pulse Sensor
1244 Camshaft Sensor
1245 Intervention AEGS
1247 Ignition Secondary Monitor
1251 Fuel Injector 1 (or group 1 for DME 1.3, cylinders 1, 3, 5)
1252 Fuel Injector 2 (or group 2 for DME 1.3, cylinders 2, 4, 6)
1253 Fuel Injector 3
1254 Fuel Injector 4
1255 Fuel Injector 5
1256 Fuel Injector 6
1257 Fuel Injector 7
1258 Fuel Injector 8
1261 Fuel Pump Relay Control
1262 Idle Speed Actuator
1263 Purge Valve
1264 EGO Heater
1265 Fault Lamp (check engine light)
1266 VANOS
1267 Air Pump Relay Control
1271 Ignition Coil 1
1272 Ignition Coil 2
1273 Ignition Coil 3
1274 Ignition Coil 4
1275 Ignition Coil 5
1276 Ignition Coil 6
1277 Ignition Coil 7
1278 Ignition Coil 8
1281 Control Unit Memory Supply
1282 Fault Code Memory
1283 Fuel Injector Output Stage
1286 Knock Control Test Pulse
1444 No Fault Codes stored
1000 End of fault code output
Hope this helps
Steve
See less See more
#2 · (Edited)
If more than one code has been detected, each code will be separated by a 2.5 second pause. When all fault codes have been displayed, there will be a 0.5 second flash and then the light will remain off. To read the codes again, turn the key off and then on again. Repeat the process above.
Here is a decent vides of the procedure. The code on this video is 1221.
1225 Knock Sensor 1
1226 Knock Sensor 2
1227 Knock Sensor 3
1228 Knock Sensor 4
1242 A/C Compressor
1263 Purge Valve
1264 EGO Heater
1266 VANOS
Hope this helps
Steve
Cool. I'm getting code 1224.
#5 ·
I added this to my "Mechanical things you need to know" sticky thread.
maybe your light is out? :dunno: when i first for the e34 the engine light had a black tape over it so it wouldn't show. then again i live in little mexico 5 mins away from the border. sell sell sell!:rolleyes:
:confused:
Steve
#6 ·
well down here it is a huge i mean huge business the export and salvage cars for rebuild at the car lots here. so at times to sell sell sell and move these cars fast, they hack them to make them seem like they are running fine and once they are in mexico they don't care.:thumbdwn:
#9 ·
I edited my original post. The video shown is not my car. It was a video that I found on youtube. I used it because it had a code that could be easily figured out by someone watching the procedure for the first time.
Fortunately for me, there is noting wrong with my car. Sorry for the confusion.
Steve
#13 ·
It will not start. I have been through the entire diagnostic procedure and have ruled everything out except the DME. I'm not getting spark. Replaced the CPS with the one from my E34 and still no spark.
One caveat on the E36 is that it is a 95 model and has the EWS II which is unique to 1995. A standard red label 413 DME will not work. It has the silver label DMW for the EWS II and it is rare to find used. Even if I found one, I would likely have to have it re-coded to my car which would involve towing my car to the dealer (35 miles) and their labor at $120 per hour, even if they would agree to re-code a used DME. I have considered sending the DME to have it rebuilt at a cost of $475. It would be guaranteed for 5 tears and there would be no recoding issues since it is the one that came out of my car.
I have been communicating with Roberto a lot and he has suggested a couple of things involving either a EWS delete chip or there is a process involving a red label 413 DME and cutting a wire and bridging some other wires on the EWS module. I'm not very good with electrical issues and am hesitant to start cutting and bridging wires. There was a lot of information in the communications with Roberto and I have to really sit down and digest it.
I will probably write a nice dissertation about it once I get it resolved.
Steve
#14 · (Edited)
well we have dealt with two EWS locked cars both 95.
First we tried on a red label ECU to test the EWS theory. When they started, we simply cut the wires that need to be looped and do the ews delete. Since in 1995 it was still a test EWS 2 on the OBD1, and not a full one that needs to have the ring and key chip in order to start. What roberto has told you is very true. try it and you will be surprised, wire is #66 but i'm sure you know that :thumbup: (sorry for the horrible sentence i was hungry and wife was calling me over to the table so i was typing with my fist)
#15 ·
well we have dealt with two EWS locked cars both 95. First we try on e red label ECU to test the EWS theory and then they start we simply cut the wires and do the ews delete since in 95 it was still a test EWS 2 and not a full one that needs to have it in order to start since it is still OBD1. What roberto has told you is very true. try it and you will be surprised, wire is #66 but i'm sure you know that :thumbup:
I'm sorry, but I'm a little confused by the run on sentence (not flaming, just not sure I'm understanding you).
I'm glad that you confirmd Roberto's assertion. I'm probably going to have to have him or someone like you to lead me through it by hand since I really don't understand electircal stuff well at all.
I don't know if it makes any difference or not, but the engine turns over fine, just no spark. Does that change your assertion? I know when I replaced the ignition tumbler a while back, I initally forgot to re-install the EWS ring and the engine would not turn over indicating that the EWS was functioning. As soon as I replaced the ring she fired right up.
Steve
#19 ·
i also co-own an e39 with my brother hehe... well let me look into this and discuss it with the guys here i'm sure I've heard this one before.... i have to go to work for now and have my hands full on a projector with AE i promised but after work i'll get full on to this :thumbup:
#22 ·
Here's another thought Rick. Watching the second video (by the way, very nice quite engine :thumbup:), I was struck by the full throttle spurts working fine, but the engine cutting out with only slight application of the throttle. This would make me think that the computer is not getting a constant progressive signal from the throttle.
I suggest that you check the throttle position sensor. I believe you have the Bentley manual and this is covered there. I have a feeling that the resistence will not be progressive as it should but will likely be showing some improper ohm ratings at about 1/8 throttle.
Please forgive me if you have documented that you've already checked it. I've read so many posts I'm having trouble keeping up with them all.
Also, if you can't do the stomp test (is your pre-92?), then it is possible that you have a code, but can't read it (unless of course you are using a code reader - can't remember).
Hope this helps.
Steve
Thanks Steve,
I'm narrowing it down to the TPS. I'll check out how to read the ohm's.
My E34 is a 94, does this year have the capability of stomp testing?
Took it for a spin, it is definitely stuck in limp mode because it stays in 3rd. I drove nice once it got going, got it up to about 35mph with no fluctuating. It's just when I take off, I have to nurse the pedal and when I slightly throttle.
#23 ·
Thanks Steve,
94 does have the stomp test ability. Not sure why yours is not working. I think it is a good chance that the TPS is the culprit on the engine problem.
I wish I knew more about the trans program error. I can't be of much help here.
Did you have either of these problems prior to your recent head rebuild?
Steve
#25 ·
Good write up, but I just wanted to add a little something: when I had my 94 530i, it did NOT advance to the next code after a brief pause like all the write-ups and procedures say, it continually repeated the same code. I had to push the pedal 5x after each code to make it advance to the next code. I started a thread and some people agreed this was the case with their car and others didn't, so it looks like there's some inconsistency across the models. YMMV.
#35 ·
I believe that is code 1000 which is what must be present to clear the codes by pressing and holding the accelerator for 10 seconds.
The only thing I can think of is that your stomp succession may have been too fast. You may want to slow it just a tad and see if you get a different result. If not, then I would go ahead and clear the codes and see if any come back when you crank and drive the car again.
Hope this helps.
#46 · (Edited)
"Well, that indicates that you know how to do it then. It is possible that the DME has failed. Here is a very lengthy thread on the subject of EWS deletion in the 95 model.
http://www.bimmerfest.com/forums/showthread.php?t=536505&highlight=ews+delete
Again, you will need to rule out all other possibilities like the CPS, fuel pump, fuel pump relay etc., etc.
The Bentley manual has a good trouble shooting guide in it. If your brother (I think that's who you said would be helping you) is not very familiar with BMWs, you may want to try to find a good local independent BMW mechanic with a good reputation and have him take a look at it.
Good luck.
#51 ·
stomp test sucess
thank you steve !!!
my ride is a 09/94 bmw 530i which was gifted to me by my bro in sanfran.
after finally getting it licensed for ontario and during the first test drive the check engine light lit up. no probs says i, i have a scanner and of course it is the wrong one for the car. so a googling i go and steve enlightens me to the stomping fritz routine. sure, why not...
yup timing is everything, youtube stomping fritz routine totally rocks...
after the first stomping sequence
dash pause dot pause dot dot pause dot dot pause dot pause
repeats 4ever
until stomp again 5x after last pause
dash pause dot pause dash pause dot pause
repeats 4ever
until stomp for 10+ seconds after dot
check engine light goes to solid on state
key to off position, turn key to start engine, check light off
woohoo !!!!
#52 ·
thank you steve !!!
repeats 4ever
repeats 4ever
woohoo !!!!
Glad the information was helpful. However, did you ever investigate the root cause of the CEL? If I'm not mistaken, you show a 1221 which is O2 sensor 1.
You may want to drive it a while to see if the code reappears. If so, you will likely need to replace the O2 sensor. If so, you may want to consider replacing them both if you are planning on keeping the car for a while.
#53 · (Edited)
yes, thanks to you, i did discover the oxygen sensor had triggered the fault code.
yes, i am planning to keep this car 4ever.
the plan was to clear the fault and see if it kept posting.
right now i am derustifing/allmetal/por15 the sunroof lip and new gasket, then on to the oxygen sensor.
thanks for confirming that it needs two, i was not sure.
the diagram at realoem looked like there were ports after each catalytic converter but only showed one sensor floating above the exhaust system.
that confused me a bit so i was going to do a physical check this weekend.
thanks so much for making life a bit easier.
#54 ·
No problem. The V-8 530 has two O2 sensors and they are both pre-cat. Good luck.
#55 ·
Stomp Test Question
1994 BMW 530i 4-door.
I did the stomp test. CEL blinked on and off...repeatedly. No codes displayed. Not sure if that means the car thinks nothing is wrong with it or not...but, since the car won't start, I know for a fact that something is wrong with it. :)
Now, I have to say...problems were already displayed on screen (3 total). "Low Beam" "Washer Fluid Low" "Brake Linings" The last one is due to my brother messing up the brake sensor when he replaced my brake. Brake pads are fine.
Do these existing displays hold up the Stomp test codes from displaying? Or, is my car's problem so simple that it doesnt even register with the diagnostic test? I just hope a code doesnt pop up that translates to "junk it." :)
Or, how long should I wait for the codes to start popping up. I waited 20 minutes and nothing. Maybe I have so many codes, the system wasnt finished processing them all.
Any thoughts?
I have to laugh...because pretty soon, I'll be crying. :)
BJ
#56 ·
Those will not interfere.
The blinking is a sequence for the code, no number will display at all.
Look at youtube videos, they will help explain the sequence.
#57 ·
+1 ^
The sequence of the blinking is the code. As Zombie says, watch the video again to figure out how to decipher the sequence of blinks.
You can also take a video of your stomp test and post it here and we can help you figure it out.
#58 ·
Yes, that may be easier for you and easier for us, explaining it is a little hard to do.
