E46 (1999 - 2006)
Old 06-21-2012, 12:22 AM
y.alkhateeb y.alkhateeb is offline
Mein Auto: BMW 325i 2004
Angry Misfiring in all cylinders
Hello everybody, i'm new to this forum, hope i'll find an answer to my problem.
I have bought a used BMW E46 engine 325i 2004 with 110K since 8 months, it was just fine until i noticed an unexpected behavior of the engine when travelling at 100 Km/h. I feel like the engine is chopping and the RPM is alternating or rising intermittently although my step on the throttle is constant. When this happen, i step more on the throttle to accelerate, i feel a strong knock on the back of the car.
I also noticed that the fuel consumption is high. There is no strange noises from engine and it starts normally. The incident only happens when travelling. I took it to the garage and the DTC showed misfire in all cylinders.
i presented the car to different garages and they have different expectations: Manifold, Fuel Pump, Spark Plugs, ....etc.
P.S I have changed the spark plugs, air filter, oil filter, fuel filter 6 months back.
PLEASE HELP ...!!!!
Old 06-21-2012, 12:42 AM
miotoo miotoo is offline
Mein Auto: F10 520d
I would say fuel pump.
F10 520d born 11.04.2011 Deep Sea Blue
205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1
Old 06-21-2012, 03:04 AM
I replaced the pump but didn't resolve the problem
Old 06-21-2012, 03:33 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
There was an ignition coil recall. Do you know if yours were changed?
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 06-21-2012, 03:47 AM
There was a leakage in one of the spark plugs, so i have changed the coil 2 weeks back and still the misfiring occurs at the replaced coil as well. Could it be the battery or battery cable head?
Old 06-21-2012, 04:04 AM
Scott ZHP's Avatar
Scott ZHP Scott ZHP is offline
We want the Lion!
Mein Auto: 03 ZHP, 01 X5, 73 MGB
Coil?
You have six of them, one on each plug.
Get the codes read and post them.
JUST...LOOK...UNDER...THE...CAR....for Chrissakes....it`s like checking to see if a dog is male or female....
Originally Posted by smolck View Post
A bimmer with forced induction should have a proper manual gearbox. Anything less is like french kissing your sister.
Old 06-21-2012, 04:41 AM
Yes, i have replaced the coil and spark plug for cylinder 2, and still reads the same error
ignition, activation coil cyl 2
ignition, activation coil cyl 4
ignition, activation coil cyl 6
ignition, activation coil cyl 1
ignition, activation coil cyl 3
ignition, activation coil cyl 5
Old 06-21-2012, 07:40 AM
Scott ZHP's Avatar
We want the Lion!
You clearly have an ignition issue. It is doubful all of your coils are bad. Double check your coil connectors and the pigtails that push onto the plugs.
Old 06-21-2012, 07:51 AM
J. Kidd's Avatar
J. Kidd J. Kidd is offline
Coyote Racing Team
Mein Auto: 2011 Mustang GT
Double-check to make sure all your ground straps are tied down. IIRC, there is one at the front and one at the rear.
2011 MUSTANG GT
Premium / Brembo Pkg / 6 spd / 3.73s
Kona Blue with Black/Cashmere Leather
Steeda Sport Springs / Roush Axle Back / MGW Shifter / BOSS Front Fascia
Old 06-21-2012, 08:56 AM
There are nice pictures of the M54 ground straps here ...
- Pictorial DIY for an M54 spark plug replacement
Old 06-21-2012, 12:34 PM
MalibuMafiaV's Avatar
L4P
Normally when ALL are misfiring it's a bad ground wire. That's from my experience at least.
http://www.luxury4play.com
2004 Maserati M128 GT
Old 06-23-2012, 11:40 PM
Thanks all for your reply, i'll try to check the grounding straps but any idea where to find those straps for the E46? Furthermore, i have read over another thread is that its possible to be an air leak from the air intake tube or hose connected to the CCV? any idea to simply check those things?
This misfire is driving me crazy ...
Old 06-24-2012, 05:29 AM
Question
Guys .. could it be the DISA or its not possible that it cause a misfire in all cylinders?
Old 06-24-2012, 05:31 AM
Scott ZHP's Avatar
We want the Lion!
You have an ignition issue, not a fuel mixture issue.
Old 06-25-2012, 02:46 AM
Talking
Could it be that the valve cover Gasket is damaged and that the oil is leaking to the plugs and coil causing a misfire in all coils? Just thinking loudly ...
Old 06-25-2012, 06:15 AM
P_T's Avatar
P_T P_T is offline
Supporting Member
Mein Auto: 323 Ci
Originally Posted by malibumafiav View Post
normally when all are misfiring it's a bad ground wire. That's from my experience at least.
1+
PT
___________________________________
Old 06-25-2012, 11:05 PM
Is the red wire a grounding strip? or its somewhere else? if yes how to replace it? its going into the plastic duct.
Moreover, why i only feel the misfire and engine cut offs only between 80 - 120 Km/hr and rarely at 60 Km/hr
Name:	Wire Unplugged.jpg
Old 06-26-2012, 08:36 AM
kbeamer's Avatar
kbeamer kbeamer is offline
Mein Auto: 2002 330ci
Agreed. Check ground wire
