47.5 vs. 48.1 PSdZData CAFD Changes
85K views 749 replies 227 participants last post by  shawnsheridan
#1 ·
FYI. The difference from 47.5 to 48.1 for the CAFD folder only is one file removed and 45 added:
Left base folder: D:\ISTA-P_v.47.5_SPdZData\psdzdata
Right base folder: D:\ISTA-P_v.48.1_SPdZData\psdzdata
Left Orphan Files (1)
cafd_00000ded.caf.001_010_004
Right Orphan Files (45)
cafd_000000ae.caf.005_005_002
cafd_000000b5.caf.010_004_002
cafd_000000b6.caf.010_004_002
cafd_000000f9.caf.007_003_002
cafd_000000f9.caf.007_003_020
cafd_000000f9.caf.007_003_022
cafd_000000f9.caf.007_003_167
cafd_00000a3f.caf.005_001_012
cafd_00000a07.caf.002_011_000
cafd_00000a08.caf.003_010_001
cafd_00000b0a.caf.000_022_000
cafd_00000b0a.caf.000_023_000
cafd_00000ddc.caf.001_011_004
cafd_00000ddc.caf.001_012_004
cafd_00000ded.caf.001_020_006
cafd_00000ded.caf.001_020_106
cafd_00000e69.caf.001_020_006
cafd_00000f9b.caf.001_005_102
cafd_000001a7.caf.000_012_000
cafd_000006c6.caf.002_009_003
cafd_000007a1.caf.005_022_031
cafd_000007c8.caf.006_006_002
cafd_000007c8.caf.006_008_003
cafd_000007c8.caf.006_008_007
cafd_000008a2.caf.000_003_010
cafd_000009ef.caf.000_019_001
cafd_0000012f.caf.012_003_014
cafd_00000014.caf.004_051_001
cafd_0000067b.caf.002_003_138
cafd_00000069.caf.009_000_050
cafd_0000106d.caf.012_007_010
cafd_0000106d.caf.012_007_011
cafd_0000124f.caf.000_003_014
cafd_00000223.caf.013_008_002
cafd_00000694.caf.003_003_040
cafd_00000794.caf.004_124_037
cafd_00000794.caf.004_124_038
cafd_00000794.caf.004_124_042
cafd_00000832.caf.002_012_000
cafd_00000893.caf.006_050_003
cafd_00000896.caf.006_023_002
cafd_00000911.caf.003_001_001
cafd_00001016.caf.001_001_004
cafd_00001082.caf.008_000_059
cafd_00001083.caf.008_000_059
See less See more
#3 · (Edited)
If you mean the 47.7 update that was recently Torrented, that PSdZData including all folders was 100% identical to 47.5, so I don't know what is up with that.
As for a full downloadable 48.1 package, I am not sure yet. I will package the 45 new CAFD's though and make them available for those already with an existing PSdZData set.
#5 ·
Done. All 45 CAFD's RAR Packaged is only 54.33MB.
#7 ·
Thanks. I already deposited it somewhere though using another host.
#9 ·
I already PM'd you brother because of your post in the other thread looking for cafd_00000069.caf.009_000_050.
#12 · (Edited)
Thank to shawnsheridan first.
Files received by e-mail cafd_00000069.caf.009_000_050, had a size of 2,016,571 bytes.
ProcessedWithError due to somebody else's file size is 2,016,576 bytes.
Think you had a problem with the file?
I look forward to hearing from you. Thank you...
log info;
Caused by: CAF cafd_000069-009_000_050 does not support FP version 01.01.5B
#29 ·
I am wondering if this CAFD needs the rest of 48.1 (.dll, .jar, etc.) to work.
I sent you another link. Try it and see if it will work.
#31 ·
#35 · (Edited)
File sent back too, same result.
I could think of, seems to require a different file.
I'd appreciate it if you send other files in addition to sent the file.
Thanks shawnsheridan...
error log info:
at java.lang.Thread.run(Unknown Source)
12-11-21 22:41:06,162 [WARN] [vin:WBAFW1100BDUXXXXX - ecu:KOMBI - da:0x60] com.bmw.esys.commons.exception.EsysExceptionHandler: PSdZ Error -- Exception in executeAsync. [C046] --- CAF cafd_00000069-009_000_050 does not support FP version 01.01.5A [1357] - SYSTEM_ERROR [SchedulerAsync-1]
com.bmw.esys.domain.psdz.PsdzException: Exception in executeAsync. [C046]
Maybe to me seems to require full 48.1 psdzdata... --;
#44 ·
If you are offering to create the Torrent and seed the full 48.1 PSdZData, PM me.
#46 ·
PM Sent, but Korean BMW's seem to have trouble still with cafd_00000069-009_000_050. We will wait and see now though if the full 48.1 PSdZData solves that problem for meddoo and webb.
#51 ·
#50 ·
Guys wait and see if the guys can code their cars with just the Cafd files. Getting the link now is moot until we find out if indeed we need to use the accompanying files that came along with the 48.1. If that's the case it's a rather large file compared to just the individual 45 Cafd files.
#52 ·
Yes, all this may be premature. We need to know if the 48.1 CAFD's will work with the 47.5/47.7 PSdZData binaries or not. cafd_00000069-009_000_050 seems to be having some issues. We don't know if it is just that CAFD or others too.
