E60 Battery Replacement
I have done a ton of researching for you and moderators please make this a sticky for battery replacement in the E60
This IS kind of a pain but if you want to save money and get it done correctly THIS is the way to do it.
Duralast Gold/Battery 95R-DLG
http://www.autozone.com/autozone/parts/_/N-5yc1s?itemIdentifier=820339
Here's the battery, AutoZone sells it for $179.99. IGNORE the AutoZone battery finder thing, it's COMPLETELY WRONG and spits out the wrong battery.
Or:
AutoCraft Gold Battery, Group Size 95R, 950 CCA
http://shop.advanceautoparts.com/we...oup-size-95r-950-cca-autocraft-gold_2130016-p
Here's the battery, Advance Auto sells it for $182.99. IGNORE the Advance auto battery finder thing, it's COMPLETELY WRONG and spits out the wrong battery.
Or:
http://www.batteriesplus.com/produc...es/94199-BMW/545I/2004-V8-4-dot4L-850CCA.aspx
SLI95RH9
Old Battery: If this is your old battery
01 Battery from Exide (Warranty Only) 110AH 850A 1 61216901815 ENDED
01 Battery from Exide (Warranty Only) 110AH 850A 1 61217591085 ENDED
OEM Battery Specs:
Cold Cranking Amps (CCA): 850
Reserve Capacity (Min): 110
Battery Length: 394 mm - 15 9/16 in
Battery Width: 175 mm - 6 15/16 in
Battery Height: 190 mm - 7 1/2 in
Post Location: Top Post
Right Or Left Hand Positive: Right
Core Charge Applicable: Yes
New Battery (this is for the one I got from Advance Auto)
Amp Hours: 110 hr
Battery Type: Lead Acid
BCI Group Size: 95
Cold Cranking Amps: 950 amps
Deep Cycle/Starting: Starting
Height: 7 1/2 in
Length: 15 9/16 in
Maintenance Free: Yes
Terminal Type: Top Terminal
Voltage: 12 v
Weight: 64 lbs
Width: 6 15/16 in
Autocraft Gold CCA 950 AH 110 RC 150
BMW OEM CCC 850 AH 110 RC 110
Other batteries that I think will work but not positive:
http://www.pepboys.com/product/details/9073748/00390/?quantity=148-690B Bosch from Bosch Premium Performance Battery Group Size 48 Pepboys $113.99
Part # 48-690B SKU: 9073748
http://www.sears.com/shc/s/p_10153_...cpncode=31-153196531-2&sid=IDx20070921x00003c
DieHard Gold Automotive Battery - Group Size 48 $149.99
DO NOT GET THE H8 BATTERY FROM WAL-MART ALTHOUGH THE CCA IS BETTER THAN OEM AT 900CCA THE AH ON THIS BATTERY IS ONLY 80 WHICH IS NOT ENOUGH FOR OUR CARS!!!!
Out of all these choices I ended up getting the Advance Auto Battery and with using coupon code HUGE50 or TPT 30 I ended up getting $50 off of the battery. For these coupon codes to work you MUST purchase the battery online and do in store pickup!!!
If you get the Autozone or Advance Auto battery (Which I would recommend doing) they will not be able to touch your car: (I did this in the parking lot of advance auto)
Under the hood use a 12 volt source so that you car never loses power!
Battery removal and installation:
1. Remove the trunk carpet/plastic floor and lift the tray containing the spare.
2. Locate the battery by pulling the rear right corner panel inside of your trunk. There should be 1-2 plastic screws that hold the panel down.
3. Use i believe a 11-13mm socket wrench to unbolt the retainer bar (black) that holds down the battery.
4. Use a 10mm socket wrench to loosen the positive and negative terminal and pull them off the battery. Note that the positive plug has two connections. Only need to loosen the one that is connected to the battery (which is closest to the North edge)
5. Use a Phillips screw driver to loosen the long gray screw on the South side of the battery. This is clipping down the battery on the bottom.
6. Once loose enough, pull the battery straight out.
7. Replace battery and then make sure the metal clip is sitting on top of the edge of the battery case (at the bottom of the battery)
8. Tight screw so battery is held down from the bottom.
9. Attach plugs to Positive and Negative terminals and tighten the nuts.
10. Tighten the retaining bar back on and put the corner panel back.
11. Start your car and let it run for a couple of minutes and drive around the block.
13. If your car has the 4x4 warning come up all you have to do it sweep your steering wheel all the way to the left and than all the way to the right and this warning will go away.
14. If you didn't use the 12 volt source and lost power to the car, you must reset the date and time and also don't forget to reset the TPMS through the I-Drive.
After this is all completed you car should now be running fine and throwing no codes if done correctly: Call your nearest dealer or Indy shop and ask how much for "battery registration" You don't HAVE to do this but I would HIGHLY recommend it!!!
My one local dealer wanted $103.99 to register the new battery but another dealership through some talking to them opted to do it for FREE!!!
So my all in costs was $156 after the discount coupon code for advance auto and PA State tax of 6%
My dealer wanted $500 for battery replacement, installation and registering. This process I admit was a pain but with this information I already saved the leg work for you. I saved myself $344 doing the process this way!!!
Or:
Or:
SLI95RH9
OEM Battery Specs:
Amp Hours: 110 hr
BCI Group Size: 95
Height: 7 1/2 in
Length: 15 9/16 in
Voltage: 12 v
Weight: 64 lbs
Width: 6 15/16 in
