:: ECS Tuning :: E36 M3 Brake System Upgrades|When Stock Won't Cut It
916 views 2 replies 1 participant last post by  ECSTuning
#1 · (Edited)
Why settle for good brakes when you can have a great ones? Stock brake rotors and hydraulic hoses are "okay," or they wouldn't be installed at the factory. But we all know the difference between stock and premium parts when it comes to durability and performance.
http://youtu.be/UJB1hdP72Zs
For your next brake job, move up to GEOMET® rotors with a baked on corrosion-fighting finish; drilled and slotted for better bite and surer stops. Then add ECS Exact-Fit brake lines, engineered to improve pedal feel; stylish enough to showcase behind your new alloys. Might want to check your brakes while both are on sale.
Click HERE for E36 M3 Front Cross Drilled And Slotted
Click HERE for E36 M3 Front Slotted
Click HERE for E36 M3 Rear Cross Drilled And Slotted
Click HERE for E36 M3 Rear Slotted
For your complete E36 M3 ECS Exact-Fit Stainless Steel Brake Lines kit click HERE
For complete pricing and availability:
Select Vehicle > Braking > Rotors (ECS Tuning Rotors)
Select Vehicle > Braking > Lines
See less See more
2
