Hi, the fan on my 318is will not switch on as it should do.
It is an intermittent problem as it will work with the aircon on if i wiggle the connector to the switch around.
The fan also works if the connectors are bridged..
Basically i am unsure which part(s) i need to replace..
The temp sensor which screws into the rad, or will it be the connector with the 3 wires going in to it? If so how do i replace this please?
thanks in advance ..
