Actually, it is not BMW at all (yes it is from Germany). Yes it fits 17 mm nut, yes there is a banjo bolt in there. Yes it uses two flat washers, .5 mm thick.
I basically sat underneath a 5 series, then it dawned on me... why the hell should we get bathed or spill coolant everywhere when you can just direct it down a bloody tube, and cap it with a 5 mm bolt. It is a washer as well.
The piping and the spout (at the bottom) are not OEM BMW, but the rest of the parts are.
By the way, makes draining the coolant much more quicker as well.
Hey Harry, so I am doing the water pump and a coolant flush, can you share how to do this? It's a great time for me to do this "mod" since the system will be empty.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
