Overblowing stock MAF, how to tune it out. - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 07-11-2008, 09:03 AM
ichbinsobose ichbinsobose is offline
Mein Auto: 95 525i
Exclamation Overblowing stock MAF, how to tune it out.
I am running 23psi from my holset on a 100% stock M50tu and I am obviously maxing out the stock MAF. I have a dyno session tomorrow morning and I am trying to get everything nailed down and a good power tune ready for then. My current tune is great for the street, but I am thinking that when my MAF maxes out at 4.9v probably at ~4k or so, I have 3k of RPMS where it is only reading the last column of timing/fueling figures... or does it ignore the MAF at WOT and read off those numbers VS the RPM's only? I am extremely rich in boost, about 11 AFR to 10psi, then it rockets off to 23psi and ~9.5 - 10 AFR for safety. If the MAF pulls 6*-10* of timing (anyone have an actual figure) when it is maxed out, I should be able to add that back to my last row relatively safely. I am sure I have another 50whp on the table here if I can figure this last issue out.
Stock m50tu, stock 3" MAF
95 525i, tuned by me on the 413 dme
Anyone have suggestions? I was going to run two wires from the ground and 5v wire on the MAF to the cabin for today, hook them to my voltmeter and watch at what load/rpm the MAF hits its max of 4.7 or 5.0 whatever, and after that add the timing and trim the fuel to the correct AFR for the rest of the rpm range.
Sorry, I usually post on bf.c but there has been a few misunderstandings and unpleasantness there recently.
Old 07-11-2008, 12:03 PM
BeRzErKaS's Avatar
BeRzErKaS BeRzErKaS is offline
U know how the game goes
Mein Auto: BM-double Who's?
Why not upgrade to a bigger MAF? Like the 3.5" from the 540i or a Porsche? It should give you all the headroom you need.
I run an Apexi SAFCII which displays MAF load (%), RPM, and a couple other things. It also allows you to apply a correction factor of up to +/- 50% to the MAF signal.
If you are doing your own tuning, and have independent control over timing, then something like this might work for your application.
BMW 3 Series - "Consistency of Purpose...Excellence of Execution."
Supercharged E36 325is 5sp
::ERT S/C, Auto-Manual Conv, SPAL Fan, Zeitronix, SAFCII, Alpine, Autotek, Orion, Angel Eyes, Tinted, Smoked, Trackpiped, and so much more::
Drop Top E46 330cic Step
::PP, SPP, CWP, HK, BT, Lumbar, Xenon, Tints, Clears, Remus Exhaust, ///M-Tech Wheels::
Old 04-15-2014, 07:55 PM
Oxide_325i Oxide_325i is offline
Mein Auto: '94 325i
I've heard alot of good things about the 540i maf, is it a recommended maf for f/i?
Old 04-27-2014, 08:36 AM
milKt milKt is offline
The Sincere.
Mein Auto: turPo m3
Not really.
It's an optional MAF for a camshaft upgrade on some M5x/S5x based engines though.
Old 05-08-2014, 10:07 AM
MWatty550's Avatar
MWatty550 MWatty550 is offline
BMW OBSESSION
Mein Auto: 14 550i & 335xi coupe
Send an email to Terry at Burger Tuning. He or one of his guys would. Also go to N54Tech.com and ask. You will get some good feedback for sure.
2012 335xi Coupe / M Sport / Black Sapphire-Oyster / Prem / HK
/ Wagner IC / VRSF CP / VRSF DP / aFe Magnum Intake / Black kidney grills/Carbon Fiber spoiler/ Corsa Catback / Custom Tune (TTSF)365HP/511tq / 235-35/19ET35 : 275/30/19ET38/ AG 359's Hyper Silver
Old 12-01-2017, 06:21 PM
monkey-leader monkey-leader is offline
Mein Auto: 330Ci
I dont know about BMW but usdm cars ive tuned didnt use the MAF at WOT. So it probably will go off your tables.
dyno, maf, turbo
