I have a 2003 540 Touring with 69,000 miles on it. I made the mistake of buying Sumitomo tires (they suck) and after a whopping 10,000 miles on them. They have feathered and I have bad steering wheel vibration between 45-65 mph.
I've been told I need new tires and am due to replace the struts and shocks. Just wondering how long struts and shocks are supposed to last. They said it wasn't urgent, but something I should do (along with buying tires and replacing my brakes). This is a pretty expensive situation so want to make sure I'm not getting bad advice.
This sounds like you need some Thrust Arm Bushings.. I have the same car and when I used to brake from 70-45 - The steering wheel would shudder uncontrollably... Once the bushings were replaced, all was returned to normal... As for your Sumis - (they make more than one model) - also premature wear could be over/under inflation, not having an alignment done properly..
As for new suspension... well your springs will be good for 200K and well your shocks/struts depends on your preference...
The bushings have been replaced, and I keep the tires inflated properly. Alignment and new tires (and brakes) are what I'll do next and see how it goes I guess.
That's good to know... try bedding in your brakes again.. i used to have a crazy shudder a day or two after autocross events...because as a noob - I would come off the autocross run(ours are 90-110 seconds) and after a sesssion of HEAVY braking where the pads would be HOT and the rotors would be too - I would pull up the ebrake - as such the pads would cool on teh rotors... when i would be ready to go for the second run and every run thereafter... more and more pad material would get stuck on the rotor.. i didnt notice the pulsating in the wheel during the runs - because my heavy braking would remove the pad material left on from the previous cool down... However, when i would get back on the road for teh drive back home... the last run's brake pad material deposit would have cooled on the rotor and make for a scary braking experience on the ride back home...
The only way I was able to rid myself of this madness, was to Re-bed the brake pads
I do this at night... on the highway... Brake from 70 to 20mph about 8-10 times about 1 minute apart.... After doing this - I drive for about 15 minutes at normal highway speeds(without applying the brakes) to cool down the brake rotors and pads...
Try this - seriously - before getting new brakes... especially if your brake sensors have triggered yet...
as for the tires... well which ones do you have?? you may just need a less sporty alignment...I always go to the $tealership for this... yeah it costs more... but my tires are evenly worn....
FYI - The parking brake system is a separate drum type braking system on the e39 that uses the inside of the rear disc as the drum. It does not use the brake discs for parking. Hence, there should be no deposits left on your discs and rebedding your brake disc pads should not impact any deposits.
Your steering wheel vibration could be due to any number of factors to include unbalanced wheels, bushings, etc.
After several misdiagnosis's, it turns out I have a slightly bent front wheel. This explains why the front tires are feathering and the back tires are fine.
One repair shop (Curry Auto in Vienna, VA) wanted me to spend $5K on all kinds of crap and didn't even mention the tires and an alignment.
So now I need to either repair the wheels or find 4 new ones that will better match the tires I need to buy. I currently have summer tires and need to go to All-Season.
Yes, that is what I'd like to do. I bought it used and someone put after market wheels on. I am looking to go back to original sizes. Who's got some free ones to send my way?
I know of several good shops in Northern VA for your BMW is you are not DIY inclined.
Curry's has a not so good reputation ... I know Matt Curry through his generous support of the local PCA club but most report having "unsatisfactory" repair experiences there.
Related Threads
BimmerFest BMW Forum
11.4M posts
754.1K members
Since 2001
