E90/E91/E92/E93 (2006 - 2013)
Old 04-14-2013, 10:46 PM
bear-avhistory bear-avhistory is offline
335is Coupe JB4-G5 ISO
Mein Auto: 2011 335is 7DCT Coupe
I think COBB was a little late putting an IS specific tune together so published dynos might be a bit harder to find. FMIC will not do much to add to the cars power but it will help the car keep what power it does have.
Kevin
2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO
2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star
2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash
Old 04-15-2013, 08:02 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Originally Posted by vst335is View Post
And not that you do need more power but if you do, spend under $1000 and you're above what M3 can do.
Whaaa? Can't never put no power down -nor- go 'round no corner fer <$1k like M3. Can't even change no lane.
But.....fer maybe skosh more, can install meth....
Old 04-16-2013, 07:21 PM
isjoey isjoey is offline
Originally Posted by CALWATERBOY View Post
That's true unless the 335i has the sport option. Then, identical.
BMW Performance Suspension can't never be real good 'cause:
  • Progressive Springs
  • Lacks LSD
  • Oil filled rubber bushings
  • Lower performance rear subframe bushings
  • Spaghetti thin rear sway
Better then "Sport", not as good as a home made M3 suspension build, ultimately only as good as the driver in the end.
Old 04-16-2013, 08:07 PM
  • Lacks LSD
Did we ever find out if the 335IS has the rumored improved subframe bushings?
Kevin
