HELP!! recently changed rotors, pads, and sensors on the rear only and the (o) light wont go away. work was done by a shop, front brakes not worked on. when should the light go away? thanks
just tried to reset brake sensor light with the help of all the posts with no luck! i will be taking it back where i had the work done, it has to be a bad sensor or installed wrong! will post outcome
found that the front driver side sensor had cracked plastic connector and was taped. made secure connection, retaped, ignition in pos. wait 30 seconds key out them start no more light.thanks guys
Thanks for the update. That kind of coincidence (front sensor going out after the rear was worked on) makes diagnosis difficult.
Related Threads
BimmerFest BMW Forum
11.4M posts
754.1K members
Since 2001
