5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
Refer to the PDF and if anyone has any problem with the file, let me know and I will post it again. This DIY is for 2004 525i with M54 engine.
Very helpful! I was able to follow these steps and successfully complete the oil filter housing gasket replacement. Do you happen to have any instructions on replacing the heat exchange gasket? This is also leaking.
I'm afraid I don't, as I don't even know where is the heat exchange gasket? Are you referring to the cylinder head cover gasket?
Thanks for the DIY. Planning to tackle this along with the VANOS. Is there an RTV Sealant used along with the gasket? Or is it simply,
1 remove old gasket (scrape) 2 clean area for new gasket 3 install new gasket
- 2003 525I Sedan - Manual Tranny, M-tech Bumpers Front/Rear, shadowline, M5 Mirrors, 19" Miro 279's, NNR Coilovers, Front lip, 50% tint, Dinan ECU Stage II, Dinan CAI, Dinan Free Flow Exhaust, DICE Ipod, Connects2/Parrot Bluetooth, SSK Kit, AC Schnitzer Shift Knob, CDV Delete, - 2008 R350 Mercedes Wagon |
No RTV sealant is needed for OFHG.
