Noises - normal?
2K views 6 replies 5 participants last post by  andy_thomas
#1 ·
:confused: New owner - 2002 325I. auto 27,000 miles. Are these normal noises?
1. The first 5-10 minutes after starting, I have some lifter noise. Sounds a bit like a diesel engine, then I will get a tick-tick-tick sound once in a while when cold.
2. I have an electrical sounding whine coming from the bottom rear of car. Possible fuel pump problem, or are they loud normally?
3. When I first put my car in reverse in the morning, I hear a slight bell-like clank noise!
I'm probably just paranoid. I'm pretty anal about such things when I buy a car.
Fortunately, I still have the full factory warranty if these are problems.
#3 ·
I'll second Artslinger - for the first few minutes in cold weather, the engine note is very rattly and spitty. My engine has a lot of valvetrain noise anyway (it's a Valvetronic) but this is noticeably louder than normal, warmed-up operation.
Mine is loud when the fuel load is low. Solution? Fill up :).
Are you at a dead stop when this happens? If I am a bit quick selecting reverse and the car is still rolling forward, the shift to R is delayed, and is accompanied by a mild audible complaint. When dead stopped, the shift is quick, and noiseless.
#4 ·
I've had my 330i for 3 months, during cold temperatures (as low as 10 degrees F.). I have never heard any valve noise, or "rattly and spitty" sounds coming from my 3.0L. Also, I don't think the 3-series engines have Valvetronic, although they do have Double VANOS. I just recently read that the new E90 3.0L will have Valvetronic.
#5 ·
Thanks for the replies, guys. I talked to my dealer, and he concurs with you on the noisy cold startup. He gets asked that a lot. And, my fuel was at about 1/4 tank. Filling it up did quiet down the pump noise. And I haven't heard the transmission clink now for a couple of days. I did kind of " wring it out " on a country road Sunday, so maybe that did the car some good. It had been sitting on the dealer's lot for a couple of weeks, so I think things just needed loosening up a bit. Man, these things are fun to drive!! I find myself driving without the stereo on just to listen to that sweet engine. I traded in a Maxima, and I was worried about stepping down about 40 horsepower. But this 325 has plenty of torque and zip. I believe it is a quicker car. I don't think I'll be happy now with anything else but a BMW.
#6 ·
Congrats on the new car !! :thumbup:
You already know this but be regular on oil level checking, I dont rely on dummy lights etc etc... One other quick note sometimes a "normal" slight tick sound is just fuel injection doing its thing & not lifters whatsoever, this is the case on my pick-up...its very quiet and smooth idle, so I can actually hear the subtle injectors working.
#7 ·
You are right - no Valvetronic in your car; the headgear is quite different. The 2.5 litre, Valvetronicked 325i I played with at the weekend had a noisier idle than the previous M54-powered car, even when warm.
