I recently replaced the guibo and center support bearing on my girlfriend's e30 ('89 convertible, 5 speed). After putting it back together, the transmission sits high on one side, and it makes a scraping sound when it's in any of the 2nd and 4th gear (the rear gears).
I had a jack under the transmission for part of the job to stabilize it. I also raised the engine several inches (by the oil pan) to lift the engine, so I could put the motor mount back on the passenger side (had to remove temporarily it to get some working room to get the exhaust off).
See pic below.
What is making the transmission sit high, and what can I do to fix it?
Anyone got a parts car, or work-in-progress, they can loosen one mount on? I'd like to confirm for sure that 'a new mount' is going to fix the problem. I have a feeling it won't. Thanks.
Found the noise coming from gears 2 and 4. There's a circular piece of metal (stabilizing part?) that goes around the driveshaft, it's part of it, you can see it (the circular part in the upper right corner) in the picture. It rubs against the 'arm' that runs between the bottom of the shifter and the transmission.
I think the driveshaft is holding the transmission higher than it normally should be?
Is there a specific way to lower the driveshaft. I don't want to drop the exhaust again...
it does automatically shorten unless you bent/was given the wrong CSB when doing the first project. i would really turn your focus at the engine and tranny mounts before you start messing with the driveshaft again
Get brave and admit it went wrong in the re assembly stage. take it to bits and put it back together properly - maybe using a manual this time. No easy way out of this.
The transmission mounting bracket is asymmetrical, and I had it turned around backwards ... I figured this out after taking a careful, careful second look.
dont know how i missed that, i was even looking at the picture for a second time now before reading your post above thinking gosh that right side mount looks squished like the marshmellow part of a s'more lol
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
