ZF 6HP26 solenoid replacement help - Page 2 - Bimmerfest - BMW Forums
Old 11-11-2014, 10:42 AM
banglenot's Avatar
banglenot banglenot is offline
Mein Auto: 2007 530
Brilliant. Thank you.
2007 530I
2003 325XI (gone)
2004 530I (gone)
2001 530I (gone)
BMW CCA Member 12+ Years
Old 11-11-2014, 10:50 AM
chrisb0003 chrisb0003 is offline
Mein Auto: 2004 545i
No problem. If anyone needs any help with the procedure just ask, though you can pretty much just follow the thread about solenoid replacement and then the Sonnax instructions take over once the valve body is out.
Oh yeah, TORQUE EVERYTHING. The valve body is like 6NM and the pan is like 8 or 10, which is nothing. The drain plug has it written on there and if you tighten that one more than what it says it will crack the pan (from my buddy the BMW tech).
Old 11-11-2014, 12:14 PM
switz switz is offline
Mein Auto: 750Li
Good work! Did you do the solenoids too, or just the zip kit?
Old 11-11-2014, 01:26 PM
I did not do the solenoids. I'm not really convinced they would be a permanent fix in my case as I did find other worn parts of the valve body. I'm also going to check with some local tranny shops and see if they have that fixture and could ream the valve body for the replacement pressure regulator valve that Sonnax makes. I think that is where my problem is. That particular valve held about half the vacuum it should and the problem is now about half as bad, so why not? LOL
Old 11-18-2014, 10:29 PM
meangreen94z meangreen94z is offline
Mein Auto: 2004 BMW 745i sport
I was leaning toward the zipkit as well. Im guessing you are referring to this overbore kit?
http://www.sonnax.com/parts/2663
Based off the bore in the picture and in reference to the valve body schematic that would be the main pressure regulator valve? What other areas did it have you vacuum test? Im guessing all the control valve bores?
How many miles were on your car/transmission? Were there any other symptoms/issues it resolved? I've had the 35-40 TCC lock up surge since I bought the car at 105k. Now at 108k. Intermittently it will surge at other speeds/gears going up an incline. It also had an delay/surge after downshifting on hard acceleration. The transmission otherwise shifts perfect, none of the other common issues(2-1 jolt, etc.). I can thank the original owner for being one of the few to change the fluid before issues arose.
My wife was driving the car last weekend and for the first time it set a fault under hard acceleration. 4F92 EGS: Ratio monitoring, clutch A-C. Im leaning toward a pressure loss issue in the valve body. Atleast before I tear into the case.
Old 11-19-2014, 06:08 AM
The clutch A pressure regulator valve was the one on mine that failed the vacuum test. My car has 99,500 miles and it started acting up around 80K. I had the slamming into gear if you were decelerating, then hit the gas real quick; that was resolved with the kit. Mine was surging between 35-40 mph, but ONLY in 5th gear. If I put it in manual and left it in 5th, it would surge any time I had very little pressure on the accelerator pedal; the speed didn't matter. I don't think is was the converter because if it were, it should do it ANY time the converter tried to lock, no matter what gear it was in. Clutch A controls 5th gear and it is also the valve that failed the test, although it was better after the kit. It held more vacuum, and the surging was A LOT less noticeable. That was my reasoning for suspecting that valve. I contacted Sonnax and they said the reason for the price ($700) on the tool was because there needs to be a .0004 clearance between the valve and the bore. I am in the process of finding out if someone can just measure the valve and bore it for me. I know some people that do machine work on jet engines that might be able to do it for me. For all the parts, what they fix, and what areas they suggest for vacuum testing, check out the instructions for the zip kit that they have on their website. Almost ALL of the areas I checked had leakage of varying degrees.
Old 12-14-2014, 03:13 PM
Well I did the zip kit as well yesterday, and went ahead and replaced the EDS solenoids while I was at it. It took about 10 miles of driving at various speeds to readapt after clearing the adaptations. The 35-40mph surge is completely gone(to this point) and the transmission shifts perfectly.
A point of clarification for the above poster. The check balls are in the top half of the valvebody as stated, but the top half is on the bottom when you remove the assembly bolts(on a table). So don't flip it over after removing the bolts. Even if you make that mistake, the bores in the passages are distinct for the check balls. If you try to place them anywhere else they won't be able to move freely.
Make sure to get the separator plate number off and order a new one in advance. Despite Sonnax's claims otherwise, it's guaranteed the gasket material will separate upon disassembly.
Old 05-10-2015, 08:33 AM
A B Able Truck's Avatar
A B Able Truck A B Able Truck is offline
Mein Auto: 2006 550I (N62TU) V8
chris0003 & meangreen94z - How are your transmissions working after your repair?? Would you have done anything differently or in addition to?
I'm resurrecting this thread because my wife experienced a limp mode yesterday. (May need Viagra)
But, I will be dropping my valve body to rebuild and any helpful tips would be greatly appreciated.
I'll also read thru Schpenxel's solenoid thread
The early bird may get the worm, but the second mouse gets the cheese.
Old 05-10-2015, 09:49 AM
Caesonia Caesonia is offline
Mein Auto: 2010 528i
Originally Posted by chrisb0003 View Post
In 5th gear cruising (not accelerating or going up or down a hill) at 35+mph, it will start to buck. Like it wants to shift but changes its mind, every couple of seconds like clockwork. I tried it in sport mode, manual mode, and regular mode and its always 5th gear only. When in manual with 5th gear selected, the rpm doesn't matter it will always do it when just cruising. Seems less harsh when you first start the car after it has been sitting over night. Also when it is cold outside.
I did have all the updates done including the transmission update (my buddy at the dealership did it for me (cost me lunch, lol), and it took a good 4 hours to program everything!). Every once in a while if I am slowing down to almost a stop, then hit the gas real quick it will slam pretty hard still even after the updates...
Chris
Chris,
I get one of the hunting on my car, and it's smooth as can be coming to a stop. But if I almost stop, and step on the gas, it's like it slips and then bumps into gear. Because it doesn't do it from a stop, and it has a bit of forward momentum, I am never sure if it's just dropped to first, and is going into second, or if it's really a slip. It doesn't do it all the time, but it makes me a little uncomfortable jumping on it sometimes. I also noticed that the car has gotten back into it's habit of being slow to shift out of park, especially on a hill. There is also a slight delay going from reverse to drive, again on a hill.
The car did go in under warranty and had a software update which made it better, but it is back again. The fluid level was checked, and the condition. Because it seems related to hills, I think this is indicative of some sort of a problem coming down the pike at me, but I am honestly quite sure what to think. My truck has a solenoid valve body and does something similar from reverse, but not any of the other similar symptoms.
My Indy friend who works on these says he doesn't notice anything to worry about, and change the fluid when it is out of the BMW, unless I have them do it. That way they have all the documentation for the car. He said he ahs gotten them to good will things often when it was out of warranty when the clear documentation was on hand, and with the work done at BMW.
Anyways, seeing stuff like this does worry me, but I figure by being aggressive it can be averted. Curious about your symptoms.
Liker is qwiker n so are Beemers.
Old 05-10-2015, 08:41 PM
I would do both the zip kit and solenoids. Don't bother buying the sonnax vacuum plate test tool like I did, just make sure you don't cut/split the o-rings when installing the zip kit.
It's 5-6 months later and it's still shifting like new or better.
Old 05-10-2015, 08:43 PM
.......Also make sure to use new fluid
Old 05-20-2015, 06:22 AM
My transmission is working great now. The longer I drove it, the better it got. Now I can't make it do the surging problem at all, even when I try. Mine does do the thing where if you don't come to a complete stop, then hit the gas, it will slam into gear HARD. I had the software update done and it is harder to get it to do it. The only time it will do it is if I try. Normal driving doesn't cause it after the update. My buddy is a BMW tech and he said a lot of the older 5 series do that and you just have to give it time to shift down before you nail the gas. He said I wasn't giving it a chance to figure out what I was doing so it just slams full pressure into first. I would definitely recommend the ZIP kit to anyone having shifting problems. Then clear adaptations in the computer and drive it. I didn't replace any solenoids; only the kit and the fluid in the pan. I might have drained a couple quarts after driving it and refilled with fresh fluid for a little bit of a flush, but nothing like a full fluid flush. The only other problem is it takes a second for reverse to engage after selecting it. My buddy said that's common on those cars also and to his knowledge they haven't come back needing transmissions. Of course the dealership just replaces them; they don't rebuild them, so I don't know how many people would invest as much money as their car is worth (almost) in having the dealership put a transmission in.
Old 10-12-2015, 04:18 PM
blademan blademan is offline
Mein Auto: 335i, X5 4.8is, e46 328i
I had the slipping in 5th gear at light throttle around 30-40mph on an e53 X5. Just over 100K miles on the car and tranny, so I did a complete pan drop, filter, and flush (dropping fluid from the tranny fluid cooler using about 14 qts total of ZF Lifeguard6. I'll post a vid for this at some point). 5th gear slip in gear completely gone. All parts from The CTSC.
I still do have issues shifting in between gears though, especially at +50% throttle. This seems like it could be solved by Zip Kit. Called a Sonnax distributor and quoted $165 for Zip-zf6-6r60.
Is this Zip kit DIY doable?
A tranny shop quoted me $500 for installation and labor of a ZipKit. Not sure which is better piece of mind, a tranny shop, or DIY, as shop video warns of many, small parts.
Old 12-29-2016, 10:02 AM
jcbryant6 jcbryant6 is offline
Just some guy
Mein Auto: 2010 550i
Were you able to get the part number from the master parts list stamped into the tranny body, or did you have to wait until you removed the megatronics? It looks as though there are 4 different plates for the GEN2 ZF and I sure would like to have the right plate before I take everything apart.
2010 550 M sport - Deep Sea Blue Pearl / Beige - Premium Pkg - Sport Auto w/ paddles - NAV - Active Steering - L7 - Comfort access - 20% Tint - Trinity 12w LED AEs - Smoked side markers - Solaris blinkers - Dinan intake
TO DO: - Dinan exhaust - throttle body -Stage 3 - Dual RPI ram air scoops
BMW CCA Member, Golden Gate Chapter
Old 12-29-2016, 12:41 PM
brewmasterflash brewmasterflash is offline
Mein Auto: 2004 525i
Definitely worth it to check on the tranny. Hard to see it so I used my phone to take a pic and that worked.
