Old 07-30-2012, 08:49 AM
mustoboy mustoboy is offline
Mein Auto: 2004 bmw 745il
Smile cam position sensors
Hello ,
I have code ,camshaft position aculator, is that the same as camshaft position sensors. I took the ones out at rear of engine , these are called cam pulse sensors, are these the same, dealer said there 4 , were are the other 2 located,also is there any way to check them.also is there any way to check coils, any help would be great
THANK YOU
Old 07-30-2012, 10:10 AM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
front of the head..
2 for exhaust 2 for intake ..
car runs normal ?
if you have a "in line coil tester" you can test it that way
Old 07-30-2012, 10:57 AM
Hello Alpiaman24
Thanks for reply, Are they the ones located in front of block ,vano valves I took 2 out yesterday
Rt side,they were clean ,I put power to them ,they seem to work Ill do the other 2 tommorrow, are these the ones you ment?
THESE ARE THE CODES SHOWING
P0013-CAMSHAFT POSSITION ACULATOR B-BANK ONE
P0306-CYL 6 MISFIRE -I THINK THAT BAD COIL-?
P0507-IDLE CONTROL SYSTEM HIGH RPM
P0492-SECONDARY AIR SYSTEM
P0103-HIGH INPUT,
THE P0492 CODE &P0306 CODE JUST CAME ON, THE OTHERS I HAD I DID A SMOKE TEST
AND SMOKE SEEMED LIKE IT CAME OUT OF REAR BLOCK BY FIREWALL PASSENGER SIDE
I THOUGHT IT MIGHT HAVE COME FROM THE CAM PULSE SENSOR,I THINK THERE IS A VACCUM LEAK THERE,
THANKS AGAIN,
Old 07-30-2012, 01:19 PM
stuartjohn24 stuartjohn24 is offline
Mein Auto: BMW E65 745i
I think it means camshaft position actuators, the motors that drive the valvetronic, and not the sensors themselves. I maybe wrong!
Try swapping the coil on cylinder 6 and see of the fault moves, that will prove the coil.
Stuart
Old 07-30-2012, 02:11 PM
what amg?
yea i would say swap coils first
492 sounds lke evap code pointing toward purge solenoid in the engine bay driver side connect to the intake manifold going to a yellowish looking bomb filter change that and 492 goes away ..
as far as the smoke test .. did you put it in from the dip stick ? or from the filler neck or from the service port after you took the shrader valve out (reverse thread)
Old 07-30-2012, 10:01 PM
Thank you Alpina24 & Stuartiohn24 for your help,
i will check and replace coil, The first code said cam position actulator,I took to the dealer said it had a vacuum leak.but i could afford his price to find out were, The car drove good but idle keep going up and down ,never stalled. I did the smoke test throught the filler cap.the smoke chemical was empty so i didnt get much smoke out of machine,but did see a little smoke from back of motor by firewall passenger side, camshaft pulse sensor,dealer also said map sensor,
ONCE AGAIN THANK YOU
MUSTOBOY
Old 07-30-2012, 10:05 PM
Sorry stuartjohn24, i also need new eye glasses thanks guys
