Status
Not open for further replies.
Official F10 Coding thread---Exploring Your F10
745K views 1K replies 94 participants last post by  DreamCar
#1 · (Edited)
I hope this will be the most intriguing thread!
We will discuss all the options available and try to share as much information as possible .
Knowledge Transfer: Find the attached pdf in the below link and go through it ... It will give you the basics to start also check the attached PDF (Thanks to modular93 fox)
http://www.bimmerfest.com/forums/showpost.php?p=6823380&postcount=6 (If the link doesnt work go to post # 6 in this thread)
How to make the Enet cable (You need this cable to connect your car and you laptop), Its not hard to make your own cable.
It would cost around 10 to 15$ to make a cable.
Please use the below link to find the detailed description on how to make your cable (Thanks to IMSw1) and also check teh attached PDF for detailed schematics
http://www.bimmerfest.com/forums/showpost.php?p=6825214&postcount=52 (If the link doesnt work go to post # 52 in this thread)
List of things that can be programed: (Thanks to All contributing Members)
Please check the Cheat Sheet for the list
Data Files Required to code your car:
F001 psdzdata covers the F01/F02/F04 7-series and F07 5-series
F010 psdzdata covers the F10 5-series and F12/F13 6-series
F020 psdzdata covers the F20 1-series and F30 3-series (There is no Z4 F-chassis yet)
F025 psdzdata covers the F25 X3-series (There is no X5 F-chassis yet).
More details in the below Link:
http://www.bimmerfest.com/forums/showpost.php?p=6827272&postcount=91
Cheat Sheet:
What Module to modify.. What Parameter and What value will be explained in the attached cheat sheet... This will have all our new discoveries going forward.
This thread is dedicated to help fellow festers! Will add more details as and when available just follow the thread for updates!
Volunteers: People who can install for others /Willing to help others with installation
1) DreamCar (NJ,MD)
2) Shawnsheridan (Houston,TX)
3) Imsw1 (Dayton, OH)
4) Svache (Oahu.HI)
5) hd750Li (DFW, TX)
6) wdimagineer (MD)
This is just the basic info... Will add more info in next two days
All the credit goes to Sean and Shawn
Disclaimer: Try it/use it/ request it at your own risk and blah blah and all that cra*P.......
Important: Please dont use "Quote" when replying... In that way it will be less cluttered and easy to browse once it is sticky... :thumbup:
Sub Threads:
SLI :http://www.bimmerfest.com/forums/showthread.php?p=6863231#post6863231
For the video lovers here is teh feast:
http://youtu.be/1dzvhZggafg
http://youtu.be/HdgecnfqoDg
Transfering your phone ring tone to your car.
Before
http://youtu.be/EG4MR-o1eSg
After
http://youtu.be/WuLUgAGypfw
See less See more
7
#1,371 ·
Model: 2012 550i
Build Date: Sep 30, 2011
Delivery Date: Oct 17th
Status: NOT WORKING
Did you ever change the tires: Yes
Tires changed by Ind Shop/Dealer: Ind Shop
Tires: Michelin Pilot Super Sport (same size as OEM non RFT)
Air: Normal Air
Hyptohesis: I wonder if the tire shop applied a TPMS rebuild kit when changing the tires. This is not unusual. Alex_C also has changed his tires and he may have encountered the same thing at the tire shop.
I suggest adding question, were tires changed at dealer?
#1,378 ·
No, I have not changed my tires at all!
I have the OEM tires with the original metal stem valves.
Model: 2012 535
Built: 8/25/2011
Status: Not working
Tires: Original RFT
gas: Nitrogen
#1,372 ·
BTW If anyone in Miami needs coding, I can help.
#1,373 ·
I know it's the F30 but it's better to have too much than too little info :) (plus, in the end, they're not that different in code)
Model: 2012 328i
Build Date: Feb 07, 2012
Delivery Date: Apr 10, 2012
Status: WORKING
Did you ever change the tires: No
Tires changed by Ind Shop/Dealer: N/A
Tires: Pirelli Cinturato P7 (OEM RFT)
Air: Not sure but I believe nitrogen
#1,374 · (Edited)
Model: 2011 535i M-Sport
Build Date: 10/2010
Status: WORKING
Tires changed by Ind Shop/Dealer: Dealer
Air: Normal Air
#1,390 ·
Your setup is virtually identical to mine except that mine is a 2012 and my tires were installed by an independent shop. I need to have the dealer look at the TPMS. I suspect the independent shop messed with the TPMS.
#1,375 ·
Guys I think you forgot the TPMS coding info in V3.0.
#1,376 ·
- 2011 535i
- 08/2010 build and 09/2010 delivery
- Status: not working
- OEM RFT - Goodyear
- Never changed tires or wheels
- air: normal
#1,385 ·
If you want I can convert it for you.
#1,391 ·
IS there any way to export all the module, section and function value fields from all the modules into an Excel sheet. Once that is done, we can get it translated and it will make this exercise a lot easier.
#1,392 ·
Have you guys looked into/found a way to correct/adjust the speed? it drives me nuts that me speed is appx 2mph faster than actual at hwy speeds (which i would figure is why my mpg are typically less than displayed)..
Aceman
#1,397 ·
Is it possible to reduce the electronic speed limiter from 155mph to 30mph? This might be useful for instance when I drop the car off for service?
#1,400 ·
@DreamCar
Hey, I think you need to change this in the PDF file:
F10/F11
X
HU_CIC
3003 TELEFON_TELEMATIK_ONLINE
PIM_DRIVING_TEXT_LENGTH
no_details / up_to_three_lines / one_page / whole_text
up_to_three_lines ???
No Noticeable Effect - NEEDS ADDITIONAL TESTING
THERE IS A NOTICEABLE EFFECT. The effect is that if you select whole_text you can scroll thru the text and email messages while in motion. Otherwise, you can only see 3 lines and are not allowed to scroll unless you are in Park.
Cheers,
Alex.
#1,401 ·
Hey everyone,
Just wanted to see if you wanted to transition the thread over to the coding forum that the mods were good enough to create for us. You can create threads based on chassis designation so we can discuss F10 specific issues or other chassis generic discussions.
It's super quiet there right now. I figured with conversations about cheatsheet, Speed Limit Information (SLI), TPMS, HUD and the like, it will be easier to track who's having problems and what in individual threads.
If you want to keep the discussion here, I fully understand that and I'll leave it at that. Here's the forum.
http://www.bimmerfest.com/forums/forumdisplay.php?f=175
Sean
Status
You have insufficient privileges to reply here.
