Old 06-16-2012, 10:54 PM
inland inland is offline
Mein Auto: 745i
Unhappy oil leak, cylinder head problem
my 2004 745 i has 104000 miles, starting leaking oil, the dealer mechanic said they found a crack in cylinder head on right,tried but could not close or seal it, and said need replac. e cylinder head for $$$$$. They denied damaging it while doing other repairs in same area
Car drives ok so long i put quart of oil every few hundred miles( initially every 600,now every 200 miles!). Any advice or thoughts why it happened and how to fix, other than replace the cylinder head for $10000 !!:
Old 06-16-2012, 11:33 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
u can get a WHOLE used motor for under $10K
i am sure u can source a source a head from a junk yard for under $1000 or around there. whatever. still not $10k!
and u can find somebody to put it in for another $1000
edit: found a cylinder head for $439 with FREE shipping
but its the left side, dont know which one u need!
http://www.ebay.com/itm/04-05-BMW-54...ht_4905wt_1163
'03 745i - modded - GONE -
Old 06-16-2012, 11:38 PM
Seven11's Avatar
President
Mein Auto: BMW
http://www.ebay.com/itm/BMW-745I-745...sories&vxp=mtr
right side
edit: search ebay, cylinder head bmw 745
there is a bunch
Old 06-17-2012, 06:46 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
Good Find Seven11
Old 06-17-2012, 12:48 PM
Mein Auto: 745i
Thanks Seven11! Unfortunately I am not much of a DIYer... so if anyone knows of any good/reputable mechanics that can do the cylinder replacement in the inland empire region (SoCal)I am all ears.
Thanks again for your help!
Old 06-17-2012, 03:05 PM
Rookie2008's Avatar
My Tech is here in Van Nuys an is a Certified Master Tech. He previously worked for Center BMW for 14yrs Before Opening his own shop in Van Nuys. All his customers are either from word of mouth or people he knew from BMW. He do not advertise. On the wall he has all his credentials from 3 series to 7 series certified on all BMW models.
Old 06-17-2012, 04:10 PM
Seven11's Avatar
President
Mein Auto: BMW
No Problem!
any good mechanic should be able to change a head for abut $1000 or less.
plus, you're in LA area, i am sure u can find a guy to put it in
