Old 04-14-2015, 10:59 AM
fiveseven fiveseven is offline
Mein Auto: E39 530i 2001
Hi,
After leaving the car for the whole night with the dipstick taken out I could read the level pretty well. It was low and that's why I wrote that I cannot see any improvement in the oil consumption after installing OCT+PCV.
I've tried to smell gas in the oil but there was no evident smell.
After ~7k miles the oil is still transparent but for sure darker then the fresh one.
I'm changing my oil this summer so I will replace the sensor at the same time.
Thanks.
Old 04-17-2015, 03:12 PM
dbarton62 dbarton62 is offline
Mein Auto: 04 Z4 3.0 S/C 6 speed
So I did the described catch can PCV mod over the winter and the vacuum it pulls is amazing.
My valve cover bolts had to be snugged down to stop vacuum leak I could hear once the engine was shut down, which I could never hear before.
Word of warning make sure the PCV valve itself is facing the right direction. Ask me how I know.
Threads towards the IM.
Old 06-03-2015, 06:35 PM
flyride flyride is online now
Mein Auto: 530i, 330i, M3
Nice install.
Old 06-09-2015, 11:51 AM
There is a unique thread today on temporarily BYPASSING the CCV, for reasons that are up to the owner, but one of which can be to TEST whether the smoke or other symptoms are due to the CCV:
> E39 (1997 - 2003) > PCV Crankcase Vent Valve Temporary Installations
Originally Posted by Alika808 View Post
I installed the PCV temporary within 1 hour. You need to replace the tubing (item #2, item #3 and item #4) with longer hoses but use the end of each tubes that came with it. This is only temporary until you have enough time to replace the PCV under the manifold. It cost me $10.00 for the hose replacement.
See also:
- How the CCV system works (1) & how the -CCV +PCV mod works (1) & how the -CCV +PCV +CATCHCAN mod works (1)
Please read the suggested threads, where the best always add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
Old 06-13-2015, 03:28 PM
PrimeSuspect PrimeSuspect is offline
Driving Dorethy
Mein Auto: 2001 530i
Is that a catch can? Yes it is. Goodbye CCV
I drained my catch can today and like some, I had more goop than I would have thought in just 3 months.
ID:	514298   Click image for larger version
Old 06-13-2015, 05:05 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
I would say thats normal. alot better than going back into your engine.
2003 X5 3.0i
Old 06-22-2015, 08:49 AM
Another non-aftermarket ccv-delete was proposed today for discussion.
> E39 (1997 - 2003) > OEM Solution to getting rid of the CCV? Kind of ingenious!
Originally Posted by BavarianE31 View Post
http://e46fanatics.com/forum/showthread.php?t=1066308
Basically replacing the M54 valve cover with a M56 one... Anyone think this would work? I'm not familiar with the problems (if any) that the M56 has relating to CCV issues (losing oil, mayo build up, etc) and whether the integrated CCV system is serviceable or not.
Thoughts?
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
