Old 05-27-2014, 09:23 PM
puddinboo puddinboo is offline
Mein Auto: 2003 BMW X5
looks like this will be my project this summer to do as my engine hydrolocked this winter with the ccv freezing up. but the 3.0i m54 in my x5 is currently running strong .smoked for a few days realy bad but getting better .doesn`t smoke unless I drive it for more than half hr when the exhaust is hot. but when it does its barely noticable.
2003 X5 3.0i
Old 05-30-2014, 07:03 PM
JDeGraff89's Avatar
JDeGraff89 JDeGraff89 is offline
Mein Auto: 04/1997 528i Auto,
Originally Posted by bimmerteck View Post
^this.
As to those wanting to eliminate the mayonnaise, run ethanol free fuel if you can find it and the volume will be reduced dramatically as it is often caused by water in your fuel being deposited in the crankcase due to blow by.
I run ethanol free and have 0 mayo
Sorry for any odd punctuation or random double letters, My phones keyboard is going Kaput.
Old 07-02-2014, 07:59 PM
macgy macgy is offline
Mein Auto: E34 M50, E39 M52, M54
Hello Guys,
Thank you for sharing, my M54 2001 E39 has been burning oil for years, power is still good though, I have changed the CCV 3 years ago but the oil consumption has been going up the last 1 year & now at the rate of 1L/500miles, I have finally decided to join the group & install a OCT.
What I did:
1. connect the hose from VC to OCT
2. Hose from OCT to PCV then to IM
3. plug the oil drain cap
I have been using 10W40 semi syn oil and after the OCT installed, I plan to use 5W50 fully syn oil.
Took me a few days to get done as I can only do it at night and due to problem sourcing for connectors and hoses.
Last night when I finally done and start the car, it run like crap for a few minutes as if it was running on 5 cylinders and engine died once (it was norm whenever I left it for a few days), what is the possible problem? anyway it was fine after it reach norm temperature.
I also discover that while the car is running, it was difficult to open the oil filing cap as the vacuum is sucking the cap, could that be the case of too much vacuum?, can too much vacuum damage the engine? BTW I used a 1 way valve which is normally use for brake application as PCV.
Old 07-03-2014, 04:07 PM
poolman poolman is offline
Mein Auto: 525i station wagon
You need to use a PVC Valve--not a one way valve--I used a PVC for an old Ford 6 cylinder engine on mine--there are others you can use though--the way yours is set up now--you have too much vacuum being pulled and it's not controlled--you will still have the same amount of vacuum though after using the PVC --but it will be incrementally pulled from the carnckcase--that's what the PCV will do
Old 07-03-2014, 05:58 PM
I know I`m on the e39 forums but I have the same m54 engine so I thought I wouls share my pics of my catch can install. I had to take a pic of my son future BMW mechanic lol.
by the way no more ccv and put about 200km with no problems at all running smooth. thanks to everyone here that has helped out .
ID:	449611   Click image for larger version
ID:	449612   Click image for larger version
ID:	449613   Click image for larger version
2003 X5 3.0i
Old 07-03-2014, 08:05 PM
Hello Poolman,
Based on your advice, i have bought the Mercedes Benz A 2710180029 Air Pump Check Valve M271, please refer:
http://www.everythingbenz.com/z/part...mp-check-valve
the valve has spring and plunger inside, I assume this is what you call a PCV?
Old 07-03-2014, 09:11 PM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
what did you reduce your hoses to? too many clamps and cuts for it not to be a giveaway
Looking for Parts for my E39- PM Me for wishlist and to deal!
2000 528i- Current Daily Driver and Project Car
2004 Pontiac Grand Prix GTP Comp G- 3.8 Supercharged. Sold to buy the BMW. Chipped, 27MPG, tons of torque.
2005 Pontiac Grand Prix GT- Traded in to get GTP. Electrical Hell.
Old 07-04-2014, 03:24 AM
I checked the pcv I just bought...it takes a little more pressure to blow through as compared to the 1 way valve i installed yesterday.. I have now installed the pcv, same strong vacuum at the oil fill cap, reading through the previous discussion again, such strong vacuum is normal, so I m going to test the car at a distance tonight.
Old 07-06-2014, 04:39 AM
Finally tested the car, felt more power & faster response, I will update on oil consumption in a week time.
Old 07-06-2014, 06:43 AM
I used 5/8-1/2 rudeucerand 3/4-1/2 reducer
2003 X5 3.0i
Old 07-07-2014, 03:07 AM
Now, i see it!...how my car burn oil, drove in 42C today, when I stop at the traffic light, notice smoke coming out from my car, took it aside and discover the hose from OCT to IM has crumple due to heat and vacuum and oil is blowing out from the valve cover due to pressure, I know this has been mentioned b4 but as i cannot find the 5/8" fuel hose, I used the gas hose.. big mistake, I release the pressure and took the car home, temporary replace with 3/8" fuel hose that I kept, all seems fine now but now i have to change the valve cover gasket next.
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
