This thread has been created to gather all helpful DIY maintenance and repair threads. To be included, please post the reasons or symptoms for the repair (if applicable), part numbers used, where the parts was sourced from (including cost), a step by step guide with photos (preferred) and any other thoughts, observations, tips/tricks/warnings and gotchas.
Please post all questions and comments relating to the DIY in the specific posts, not on here. As the number of DIY entries grows, I will organize them by category or section.
All DIY threads are for your reference only, should you choose to follow any advice on these threads, you assume any and all responsibility for any risks, damage or other unexpected or unintentional consequences.
DIY REPAIR
Battery Replacement
Engine Air Filter Replacement
Changing Turbo Oil Lines
Changing Turbo Coolant Lines
Rear Door Sunshade Disassembly
Remove Front Bumper to Replace Headlights
Low Pressure Fuel Sensor
Front Brakes (Rotors and Pads)
AC Blower Motor (performance maintenance or replace filter) Noise due to debris
N63 Valve Seal Replacement DIY
BMW F01 Night Vision Retrofit DIY
REFERENCE
Wheel Bolt Torque Values
MODS
Top/Surround View Camera Retrofit
DIY REPAIR
Battery Replacement
REFERENCE
MODS
