My 5 years-old battery needs to be replaced. Does anyone know which one should I choose between AutoCraft H6-AGM and H8-AGM? The prices are the same. The H8-AGM is bigger, but it's smaller than MAXX-H8. The specs are as follows:
H6-AGM:
Acid Included: Yes
Battery Type: AGM
Battery Usage: Auto/Truck
BCI Group Size: H6
Cold Cranking Amps: 760
Cranking Amps: 950
Deep Cycle/Starting: Dual Purpose
Height: 7.5
Length: 11
Maintenance Free: Yes
Reserve Capacity: 120
Terminal Type: SAE
Voltage: 12
Weight: 45.66
Width: 6.938
H8-AGM:
Acid Included: Yes
Battery Type: AGM
BCI Group Size: H8
Cold Cranking Amps: 900
Cranking Amps: 1000
Height: 7.5
Length: 13.94
Reserve Capacity: 160
Terminal Type: SAE
Weight: 59.45
Width: 6.938
BTW, MAXX-H8 size (L x W x H): 14.31 x 6.88 x 7.5
Thank you very much!!
H6-AGM:
Acid Included: Yes
Battery Type: AGM
BCI Group Size: H6
Cranking Amps: 950
Height: 7.5
Length: 11
Terminal Type: SAE
Voltage: 12
Weight: 45.66
Width: 6.938
H8-AGM:
Acid Included: Yes
Battery Type: AGM
BCI Group Size: H8
Cranking Amps: 1000
Height: 7.5
Length: 13.94
Terminal Type: SAE
Weight: 59.45
Width: 6.938
