What brake pads and rotors are most often recommended for street use for your bimmer?
See also:
- What friction grade (e.g., EE, FF, EF, etc.) is recommended for BMW brake pads (
1) (
2) & what street use brake pads (
1) and rotors (
1) and suppliers (
1) (
2) are most often recommended & how to do a complete four wheel brake job DIY (
1) (
2) (
3) including the parking brake drum shoes (
1) (
2) (
3) & exactly what lube/paste to use and not use (
1) & where to lube (
1) and not to lube (
1) & what six brake hoses to check for wear (
1) & how to do a preventive brake system & caliper rebuild (
1) (
2) & what tools are needed for a brake job (
1) (
2) and supplies for doing brakes (
1) & what brake specifications you must know (
1) including minimum specs for the brake shoes (
1) (
2) taking care to measure torque accurately (
1) & how to crack friction material edge codes (
1) & how far you can go once the brake wear sensor trips (
1) (
2) (
3) (
4) & how long do rotors last (
1) & what's the real difference between drilled, slotted, and solid rotors (
1) & what's the difference between various brands of solid rotors (
1) & how to clear the check brake lining warning the right way (
1) (
2) and how to hardwire the sensor (
1) (
2) & how to diagnose brake-related vibration (
1) (
2) (
3) & the truth about rotor "warp" (
1) & how to rebuild the calipers (
1) & how to measure runout (
1) & should you just turn the rotors (
1) & how to remove stuck rusted-on brake rotors (
1) & how to remove a stuck 6mm brake rotor set screw (
1) & how to replace the anti-rattle spring (
1) (
2) & what about unsightly rust (
1) (
2) (
3) (
4) (
5) & how to bed (
1) (
2) & bleed or flush (
0) (
1) (
2) (
3) (
4) (
5) your brakes & what brake & clutch hydraulic fluid to use (
1) and how much it will cost if you do not DIY (
1) (
2) (
3)
