I have a List put together and curious if you could look it over to see if i am missing anything. i believe i have it all
This is all NX parts
EFI FUEL PRESSURE SAFETY SWITCH ONLY
SKU : 11720
No, because you also need the 4an manifold, plus this one is adjustable.
http://www.ebay.com/itm/111603400326?_trksid=p2060778.m1438.l2649&ssPageName=STRK:MEBIDX:IT
NITROUS PRESSURE GAUGE ONLY (0-1500 PSI)
SKU : 15508
That's fine, but the DynoTune unit is cheaper.
www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=143
4AN NITROUS PURGE VALVE SYSTEM
SKU : 15600
Not really needed. A superior way to do this would be to replace the standard 15' -4 line (supplied with any nitrous kit) which is to BIG, and replace it with a custom DynoTune ~12' -3 line (you need to measure) with 4an ends on it.
www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=338
4AN PURE-FLO N20 FILTER & 7 STAINLESS HOSE (LIFETIME CLEANABLE)
SKU : 15607
Buy this one from DynoTune at half the price. (1/8 NPT, Most Street Solenoids)
http://www.dynotunenitrous.com/store/Scripts/prodView.asp?idproduct=97
10-15LB HEAVY DUTY FULLY AUTOMATIC BOTTLE HEATER (4AN) 14AMPS
SKU : 15940
Buy this one from DynoTune for half the price. (4an)
www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=17
BOTTLE INSULATED JACKET (10LB)
SKU : 15945
Buy this one from DynoTune.
www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=71
PROTON SERIES NITROUS SYSTEM W/ 10LB BOTTLE
SKU : 20420-10
The 20420-10 Proton saves you about $30 dollars compared to the better 20421-10 Proton Plus, I'd buy the 20421-10 Proton Plus.
http://www.amazon.com/Nitrous-Expre...F8&qid=1432400740&sr=8-1&keywords=proton+plus
I am not sure i need this part or not
STAND ALONE FUEL ENRICHMENT SYSTEM(SAFE), EXTERNAL PUMP AND REGULATOR
SKU : 15003
Not needed.
Also
there are 2 controllers
MAXIMIZER 4 PROGRESSIVE CONTROLLER
SKU : 15957
This is a very good unit, but it's roughly $400 dollars. I'd buy the NOS brand 15974 Mini 2 Nitrous Controller which costs a lot less.
http://www.amazon.com/NOS-15974NOS-2-Stage-Progressive-Controller/dp/B000LWID7Y
PROGRESSIVE CONTROLLER (45AMPS MAX)
SKU : 15835
This entire list works out to roughly $1050, not including your wideband AFR kit which you already own.
Also buy a set of BKR7EIX # 2667 & gap them to 0.029". You said you already have a wideband AFR kit, if you didn't I'd probably recommend this one.
http://www.amazon.com/AEM-30-4110-U...im_263_35?ie=UTF8&refRID=19F6T2WQWAHFXFRTJBAY
Rob43
