I was just curious if it was normal for the clutch pedal to be able to move from left to right if such forces were put on it. This makes it very frustrating when you have a clutch stop and you worry about pushing the pedal behind the stop. it just seems too sloppy. If this is a problem, is there a simple remedy?
I have the same annoyance, but not that badly, so I'd say its not quite normal. Mine will shift a bit though. Mine can shift maybe a cm or so, but definitely not enough to clear the clutch stop. I'd try to adjust what holds the pedal in place though I'm not quite sure what that'd be.
I fyou have to worry about pushing it around your clutch stop, thats a lot of movement, and definitely a problem.
Of course... I jotted that too quickly. The pedal moves about 3 to 4cm either way. It's more of a dampened movement, where as it moves farther it begins to counteract the force you put on it rather than just clunking side-to-side.
If I say take my car outta gear really fast and push real haard (kinda gripping so i dont slide) than say start turning and downshift.. right b4 i engage itll shift on me a bit every so often..
I looked for UUC Bushings and found the right away. However, could I just run to the hardware store and fing some bushings or is it reccommended that I buy some?
+2 on the bushings, yours are shot if the pedal moves sideways 4cm.
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
