It all started when I had unusual stagger while driving, it seem like it was running out of gas even though it had gas.
I changed the fuel filter. Still rough idle. I had codes P1083,1085, 0171,0173.
I changed the spark plugs. Still rough idle. Driving uphill I would loose power. I was getting a Trans. Failsafe prog.
I changed the CCV valve. No improvement except no more P1083,1085. And no trans. failsafe prog.
It was leaking oil, I changed the gaskets.
I cleaned the MAF, smoked the engine for vac leaks (none) and still it won't even turn over.
I have no more OBD codes, but it is dead in my garage.
Any suggestions? Fuel pump? transmission gear box? since it won't start it's hard to diagnose. Or do I give up and take it in?:dunno:
