Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 12-22-2010, 09:19 PM
Docboy78 Docboy78 is offline
Mein Auto: BMW 645ci
Transmission Leak
I recently noticed a leak in my transmission and wanted to investigate where the source can be located. It isn't coming from the bottom seal, I know that for certain. Can anyone direct me to a diagram of the transmission for a 2005 645ci? Has anyone else had this issue before?
Old 12-27-2010, 09:00 PM
hipertec hipertec is offline
Mein Auto: 2005 645ci
yes, its a cracked transmission pan. typically where the bolt is holding the pan. its made of plastic. its like a hairline crack, cant even see it until you lift the car up. A piece of crap since mine and a few others had to replace. Get ready to spend 800-1000 for replacement.
2005 BMW 645ci - DPE 3pc Forged Rims, Coilovers, Britalman full cat-back exhaust system, , K&N Air Filter, LUMMA Roof & Trunk Spoiler.
Old 01-27-2011, 02:24 PM
Jagular's Avatar
Jagular Jagular is offline
Mein Auto: '04 645Ci
I'm doing mine for $433.28, not $800 to $1000. How? Glad you asked:
I bought the OEM oil pan replacement kit from eBay. Either search for part number 24117571227 or BMW transmission pan; there will be many models that have the 4.4 or 4.8 litre pan available, including gaskets, filter, etc. I chose to stick with OEM even though it cost more than the knockoffs. Cost? $185.12 shipped. Purchase 5 quarts Red Line Synthetic D4 ATF, $58.17. Take it to Aamco. The labor quoted locally is $189.99. They are cool if I supply the parts/fluid and they warranty their work but not the parts, obviously. Total? $433.28 including shipping.
'04 645Ci, Saphirschwarz Pearl/Black, auto, sport, cold-weather, 19" chromes, Logic 7, 7k white angels, MP3 retro, iPod retro, black grills/gills, Bluetooth retro, upgraded microphones, piano black interior trim
'12 Nissan LEAF, Cayenne Red
'10 Victory Cross Country, Black, too much to list
'01 Honda Magna, Black, too much to list
Old 03-06-2011, 05:33 PM
Jagular's Avatar
Wanted to follow up on this. After discussing the Red Line D4 ATF option with a few folks, I decided to go with the standard Shell M-1375.4 instead, costlier but needed for the ZF transmission.
Old 06-02-2012, 11:58 AM
BeastMW BeastMW is offline
Mein Auto: 2005 BMW 645 Coupe
No DIY for this issue?
2005 645, 22in Giavanna's, Stratus Grey Metallic/Black int., custom quad exhaust, blue angel eyes, 30% tint
Old 06-03-2012, 09:39 AM
Yorgi's Avatar
Yorgi Yorgi is offline
It looks easy enough, here are the TIS instructions.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-24-2012, 07:09 PM
daf290 daf290 is offline
Mein Auto: 2007 650 I
Check ATF flluid level
Can anyone confirm the procedure to check the ATF fluid level?
I have read the TIS and have attempted to complete the fluid level check but I am not certain that I have located the correct plug to remove and fill. Is it located on the left front?
On the TIS, it looks like it is in the rear but I only find a plug with removal by a hex head on the left front up almost half way on the trans case.
Is this the correct plug?
Old 02-12-2013, 07:09 AM
OUalacra OUalacra is offline
transmission pan bolts
Does the TIS instructions for oil pan replacement say anything about providing new bolts? A tech told me the pan bolts are one time use only.
Old 04-01-2013, 05:15 PM
Chesterhoss Chesterhoss is offline
Mein Auto: 2004 645ci
Hey guys, just wanted to give ya a heads up I got the same thing goin on and I found these:
http://www.ecstuning.com/BMW-E63-645...ion/ES2523912/
http://www.ecstuning.com/BMW-E63-645...ion/ES2523911/
I myself am probably gonna go with the shell fluid and do it myself (doesnt look too difficult). any cautions or warnings before I jump in?
Old 04-11-2013, 06:23 AM
dsanders dsanders is offline
Mein Auto: 645ci,and 735il
Hello; I am currently having problems with my 6 as well. I took it in to the dealership and they informed me that I have some leaks one being having A transmission sealing sleeve replace as well as a upper timing case cover replace... Pricey!
Old 04-11-2013, 06:35 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
50k miles with redline so far.
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
