I think they're talking about bleeding.
If you're overheating, you first:
a) check if air is blowing over the radiator (i.e., fan)
b) check if water is circulating (i.e., waterpump, thermostat, leaks)
c) check if air is circulating instead of water (i.e., bleeding)
Since overheating is the number one problem in these engines, there is more information than you can possibly imagine on your specific problem.
If it's a simple overheat, these set of links (from the E39 bestlinks) should help:
- What to look for when your KTMP (
1) or coolant temperature gauge indicates overheating (
1) (
2) (
3) (
4) (
5) (
6) (
7) (
8) (
9) (
10) (
11) & what to look for in a perfectly normal E39 cooling system (
1) & a picture of every failed part in the cooling system (
1) & various techniques to properly bleed (
1) (
2) (
3) & refill (
1) & drain (
1) (
2) & flush (
1) & what coolant to use (
1) & what parts to replace (
1) (
2) & how to retrofit brass bleeder screws (
1) (
2) & what special tools to make or buy (
1) & how to tell how old your cooling system is
(1) (
2) & how to test the cooling system auxiliary electrical fan (
1) (
2) (
3) (
4) & a DIY for replacing the auxilliary fan (
1) (
2) (
3) & the infamous fuse 75 (
1) & the aux fan relay (
1) & how to diagnose lack of HVAC/IHKA heater core heat with cooling system (auxiliary pump) at idle (
1) & a Behr radiator and Behr/Heat expansion tank autopsy (
1) (
2) & request for another Behr surge tank autopsy (
1) & why new made-in-China Behr/Hella expansion tanks are DOA (
1) & E39 Fan shroud removal DIY (
Besian) (
M54) & some of the better cooling system DIYs (
cn90 1997-1998 M54TU) (
cn90 V8) (
aioros '99-03 M54) (
Ågent99 '01 530i) (
pelican 3-series) (
bluebee M54B25) & tricks to replace the fan clutch nut (
1) & lower-hose thermoswitch o-ring (
1) & to non-destructively remove the heater hoses (
1) or radiator nipple (
1) or expansion tank nipple (
1) (
2) or Oetiker clamp (
1) or misplaced thermostat wiring loom (
1) or broken bleeder screw (
1) & modifying the cooling system pressure cap (
1), or using propanol-based zero-pressure fluids like NPG+ (
1) (
2) (
3) (
4) (
5) or all-aluminum cooling system parts by Zionsville (
1) (
2) (
3) aluminum radiators & what happens if you drive one mile too far with an overheated BMW cooling system (
1).
If it already overheated, causing damage, these will help:
- Summary advice to provide users who suspect a major engine repair due to overheating (
1) (
2) (
3) (
4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (
1) (
2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (
1) & a DIY for replacing the I6 M54 head gasket (
1) (
2) & replacing the V8 M62TU head gasket (
1) & why these engines are so prone to heat-related damage in the first place (
1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (
1) & what engine swaps are most recommended (
1) (
2) (
3) & where to obtain a new or rebuilt head (
1) replacement short block or long block (
1) (
2) & how to lift & remove the engine (
1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (
1) (
2) (
3) (
4) (
5) (
6) (
7) (
8) (
9) (
10) (
11) (
12) (
13) (
14) (
15) (
16) (
17) (
18) (
19) (
20) (
21) (
22) (
23) (
24) (
25) (
26) (
27) (
28) (
29) (
30) (
31) (
32) (
33) (
34) (
35) (
36) (
37) (
38) (
39) (
40) (
41) (
42) (
43) (
44) (
45) (
46) (
47) (
48) (
49) (
50)
