Gurus,
I need help on coding.
I coded my 2014 X3 35i this morning for Close mirrors+windows+moonroof through comfort access and key fob and it didn't work for me. I coded following functions:
CAS -> 3003 FH Master -> KOMFORTSCHLIESSUNG_FB = aktiv/Werte = 01
CAS -> 3003 FH Master -> KOMFORTSCHLIESSUNG_PA = aktiv/Werte = 01
Updated value for ASP_BEIKLAPPEN_BEI_KOMFORSCHLIESSEN also under FRM.
I didn't get any errors while coding or after the code with software or my car. I tried reading the values back and the changes didn't take effect. Software is still pulling old values from Car.
I did CODE FDL as last step in my coding and then disconnect. Is thr an additional step after CODE FDL to save values? Any one could point what am I missing here?
