Discussion pertaining to the flagship BMW here. |
Replaced the guibo today
and man I'm impressed with the undercarriage. I love the plastic and aluminum shielding....keeps the unibody looking like new under there. I never thought it would be so easy to do. Between the TIS and Keif's photos it was a 2.5 hour breeze...although I did cheat and use my trans jack to lower the exhaust and hold it up with ratcheting straps to save time. Test drove the car and wow what a difference....guess that part isn't designed to last more then 50k or so. Next week will be the coolant hose and sensor.
2007 Kawasaki Ninja ZX-14 2006 BMW 750i 1972 Dodge Charger 1968 Dodge Charger 1967 Austin Healey Sprite Last edited by MOPAULY; 11-20-2010 at 04:02 PM. |
Nice work
650i sport hud asanti af132 |
Good job... Nice ZX14....Although my next bike will be a Busa. Did you have downshift problem with jerking from 2-1?...is that why you replaced the guibo?
Thanks. No down-shift issue really, just a clunking letting off the accelerator and going into gear sometimes. The old guibo had a ton of visible slop in it, you could move the driveshaft back and forth and visibly see it. Not sure why the dealer charges so much for this...I'd do it all day long for $400 plus the guibo.
2007 Kawasaki Ninja ZX-14 2006 BMW 750i 1972 Dodge Charger 1968 Dodge Charger 1967 Austin Healey Sprite |
Is that your home garage with a lift? I love something like that!
Black 2002 BMW E65 / 745i 114K My DIY's - New alternator, battery, CCVs, idler/tensioner pulleys belts, NGK Iridium spark plugs, , sway bar bushings, Front rear brakes, Valve Block, Head Gasket, Exhaust Gasket, Upper and lower Timing Gaskets, Valve Covers, exhaust valves, Timing Chain slide rails, Fuel Injector o-rings, pulled radiator, Intake Manifold Gaskets, water pump, Coolant Pipe/weep hole, oil pan gasket, vacuum pump, fan shroud, Vanos solenoid o-rings, and timed it with a timing kit. |
Indeed sir. I have a 2 post lift for maintenance services and a 4 post lift I use for storage.
2007 Kawasaki Ninja ZX-14 2006 BMW 750i 1972 Dodge Charger 1968 Dodge Charger 1967 Austin Healey Sprite Last edited by MOPAULY; 11-22-2010 at 05:40 PM. |
So very jealous right now.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... Last edited by Keif; 11-23-2010 at 08:43 AM. |
Yep I did the adaption as well, she used to shift waaaay early. I didn't change the trans fluid but had been contemplating it, I used to do it every 15k or so on my Dodge, and she still has her original trans at 194k.
If it shifts well now, I vote not to mess with a good thing. Just my $0.02.
White 2007 Alpina B7 Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts Black 2002 BMW E66 / 745Li (sold) KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights... |
Is your 2 post Asymmetric? Could you do me a favor and let me know where the posts end up on your 7? maybe a measurement from the front to the post and the back to the post. I'm about to install a Rotary 10K Asymmetric in my garage and want to get it close to right on the money. Last edited by racerock; 11-23-2010 at 08:00 PM. |
whats the part number for the guibo? thanks!
Just got my car back after my Indy replaced the guibo. MAN!!! What a difference. Smooth as hell.
03 745 Li//Black Kidney Grilles//MTECH V2 Lights//MTECH HID fogs
seb - sorry I already threw out the bag with the part number on it...
OK, thanks, that would be greatly appreciated. I'm surprised you said dead center - was expecting something towards the front of the front door (A pillar area) and not between the doors (the B pillar). Nice garage by the way. What bike do you have?
you know, I think it is actually closer towards the a pillar, I thought I had a photo on my phone but do not; i'll def take a pic this weekend if I put in the air again.
part number for the Universal Joint/Guido for 745LI 2004 is:
26117572664 It also fits a bunch of other years including the 750's Last edited by racerock; 12-29-2010 at 08:54 PM. |
Got mine replaced this week (2005, 66k miles). Ran about $750, not covered by CPO warr. (ouch). But, made a nice difference.
found the part number. thanks!
Can anyone confirm that the guibo partnumber here is for the 750s as well. The guibo for a 750 is showing up on realoem as a different part number. See below 745 Guibo http://www.realoem.com/bmw/showparts...89&hg=26&fg=10 750 Guibo http://www.realoem.com/bmw/showparts...89&hg=26&fg=10
By the way, I have not replaced my guibo yet... Still running well after resetting the trans tables to zeros to relearn after replacing the trans fluid and filter... Knock on wood, it is running well. |
Sorry guys if I'm supposed to post here and not meaning to highjak this thread. I alo posted a few days ago at sell/buy threads but got no responces even though price is cheap, well at least i think it cheap because i paid much more. This is how my post looks there; BMW e65/66 Driveshaft Flex Disc universal joint OEM guibo coupler
Hi, selling this OEM part because traded in my car and no longer need it. I paid $150.00 plus shipping cost, but willing to sell it for $110 including shipping cost. New Yorkers welcome for in person transaction. As a bonus i will include also set of two cabin charcoal filters, its a good brand, sorry its in the box in my car in parking lot can't go to see a brand. Sorry again guys.
Beautiful home garage setup and car/bike collection.
SOLD 2003 745Li Authentic AC Schnitzer Aero Kit inc Front, Side Skirts, Rear, Mirrors, Roof and Trunk Spoilers Gloss Black Grille and Window Trim KW Variant 3 Coilovers 22" Interad Turismo Forged 3-piece wheels |
