Mine always opens when I pull on the handle above the license plate, as long as the car is unlocked. Why would this be surprising? That's how it should work isn't it?
Maybe I'm missing the point. What does the manual key unlocking the trunk have to do with anything, and why would you want to when you have a remote? :dunno:
Why are you surprised? There is a release button right there where you are pulling up. Now, if its opening when its locked, that is another issue. I'm unclear as to what the problem is though...
I might be a little confused... but isn't the trunk supposed to open when you manually use the key, and when you use the handle above the license plate????
I must ask...have you read your owners manual to get an understanding of how your trunk works? Not sure why you feel it is "stupid" to have the option of having the trunk connected to the central locking system or separated from the central locking system. You can change the way your trunk operates if you think it's stupid to have the ability to open the trunk when the car is unlocked. See SECURE SEPARATELY in image below from owners manual.
The trunk can be put into valet mode by leaving the trunk lock cylinder in the HORIZONTAL position ( -- ). This appears to be how you think the trunk should work and not be "stupid". This means you'd ALWAYS have to use the remote button on the key, or stick the key manually into the trunk lock cylinder to open the trunk.
BMW gave owners another option .... and that is to have the trunk connected to the central locking system...which means the trunk can be opened any time the doors are unlocked. If you lock the doors, the trunk is also locked...if you UNLOCK the doors, then you can also access the trunk without having to insert the key into the cylinder.
If you leave the trunk lock cylinder in the VERTICAL position ( | ) the trunk is connected to the central locking system...anytime you have the doors unlocked you or passengers have easy access to the trunk...all that is needed is to press the release button (see text below highlighted in yellow from owners manual):
Related Threads
BimmerFest BMW Forum
11.4M posts
753.1K members
Since 2001
