Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 12-28-2005, 10:35 PM
ChrisF ChrisF is offline
Mein Auto: 2002 330 xi
Sunroof Shade Clip DIY
Like many others, I've had problems with the sunroof shade on my 330. It was not sliding properly and was binding up when I operated the sunroof. There are four "clips" that attach the shade to the slider mechanism that are notoriously poorly designed. It doesn't take much to break them.
I put together a quick Sunroof Clip DIY (with pictures) describing how to replace these clips.
When I did this repair I found that none of my clips had actually broken. In my case, one of the clips on the right side, had popped out of the slot in the sliding member and it was causing the shade to bind up when the sunroof was opened/closed.
Now that I've had it apart, I'm certain that I'd be able to replace them if/when my clips break.
Enjoy.
ChrisF
2002 330xi, 5-spd, Orient Blue w/ Sand Leather, SP, PP, Xenons
Old 12-29-2005, 09:53 AM
qu4ttro's Avatar
qu4ttro qu4ttro is offline
Mein Auto: 01 325i, 08 335i
Very nicely done, Chris!
ED - Mar 30, 2008 - e90 335i
A/W | Terra | Burl | ZSP | ZPP
Step | Paddles | Nav | CA | iPod
Old 01-07-2006, 07:00 AM
srcstc srcstc is offline
mybimmer.net
Send a message via AIM to srcstc
Mein Auto: 09 TiAg E92 335i M-Sport
Yes very nice. This turned out to be one of the easiest DIYs.
Rich
Old 01-31-2006, 06:32 PM
Hutchman Hutchman is offline
Mein Auto: 2011 328i, 01 325I
My shade wont slide back beyond two inches. My question is.....how do I loosen the 6 torx screws when I can't get to them? Anyone???????
Old 02-01-2006, 08:24 PM
blkonblk330i blkonblk330i is offline
Mein Auto: 06/2000 330i ZSP/ZPP
flip moon roof up and you should be able to slide shade back.
Never argue with an idiot. He will drag you down to his level then beat you with experience.
Old 02-04-2006, 09:53 AM
That is the problem, it wont go back more than 2 inches. It was like that when I bought it used. It goes back with the glass when it is opened, but comes back up with it when it is closed. I would like to fix it, but I don't want to brake anything in the process.
Old 05-02-2008, 01:54 AM
dimantslv dimantslv is offline
Banned
Mein Auto: BMW
nice yob!
Old 05-30-2008, 07:54 PM
bavenda bavenda is offline
Mein Auto: 2000 M roadster
what is the part number of the "driver"
I can't find the part number in the diagram.
Enjoy.
Old 11-08-2009, 05:58 PM
jvd626 jvd626 is offline
Mein Auto: 2001 BMW 330i
Were you able find this part number of the "driver"? i can't seem to find this driver in the realoem.com catalog.
Old 11-09-2009, 06:58 AM
pish180 pish180 is offline
Mein Auto: 2003 330xi
I've been looking for the slide stop (part behind what you circled).. I guess our best luck is to go to a junk yard. Its not listed on realoem.
Old 10-20-2010, 12:20 PM
darianva darianva is offline
Mein Auto: 330 sport
Hi All,
I hvae recently run into the issue where my sun roof will not open in slide mode fully.
It appears as per the forum that something on the lid/cover has broken and prevents the roof from fully opening.
I woud like to use johnewhites plan to open the roof while holding the cover lid closed, however I am not able to close the lid/cover as it gets stuck halfway.
Does that leave me no other option that to remove the roof by lifting it out after removing the 6 torx screws?
thanks
darian
Old 10-20-2010, 12:49 PM
BM-MAN BM-MAN is offline
Mein Auto: BMW 323ci
Originally Posted by darianva View Post
Hi All,
thanks
darian
I ran into the same issue. You have to keep giggle the lid back and forth until it comes loose.
My next whip!!!!
Old 09-01-2011, 01:10 PM
strombou strombou is offline
Mein Auto: 2002 325i BMW
Thanks guys for the posts, I have the same issue and will attempt to DIM since I'm now armed with valuable knowledge and have a starting point and a direction to follow. If anyone has the part numbers to this kit, that would help. I have a 2002 325i BMW.
Old 10-09-2011, 09:18 AM
jordanfanx23x jordanfanx23x is offline
Mein Auto: 2000 BMW 328i Sports Pack
Even easier DIY
Another way of doing this that is much easier iswithout removing the glass. The shade slider has 2 very flexible rubber pieces at the front of it which is used to push it back when the actual glass moves if you just slowy open it and pass these two rubber pieces under it you can open the glass fully and work only with the shade slider. There are 2 perks i noticed when i did this:
1. you dont have to worry about placing the glass back on correctly and no need to recalibrate it in some cases
2. you can remove the entire slider and still close close your sunroof normally, so like for me, i could still drive around with no worries while i waited for the parts to come in!
Pt #'s
54-13-8-246-027 (left 2 needed)
54-13-8-246-025 (right 2 needed)
Old 11-08-2011, 10:25 AM
kuyaedou kuyaedou is offline
Mein Auto: 2003 BMW 330i
good job!
This post saved me $260+ from the dealership to have it fixed! Thanks for sharing your detailed work for the sunroof man!
Old 11-10-2011, 01:12 PM
No Problem! Glad it helped!
Old 01-13-2013, 08:14 PM
monkeyhead monkeyhead is offline
Mein Auto: 2003 330i
Hey Chris, thank you for the sunroof DIY, it saved me mula
Old 07-19-2013, 02:44 PM
ejkuch ejkuch is offline
Mein Auto: 2001 330ci Coupe
Thanks for sunsadediy! Fixed my problem in 15 minutes!!!
Old 08-24-2013, 04:24 PM
bcain79 bcain79 is offline
Alpha Phi Sigma
Mein Auto: 2001 BMW 530i
This is a great thread! Thank you for putting the DIY together for this!
2001 BMW 530i e39 / Automatic / Orient on Dove
Old 12-01-2013, 12:07 PM
mrgilbert mrgilbert is offline
Mein Auto: 2005 330i
do all cars have a "driver" i have an 05 330i and my sunroof rattles when i try and open it the shade doesn't close all the way either and no clips are broken what i do notice is that the passengers sliding tab doesn't move. i have no problem sliding the drivers side back and forth
Old 12-01-2013, 03:10 PM
maybe you shade doesn't close all the way because the glass is sitting to low, readjust the glass to a higher height, unscrew the lid retaining screws, push the glass up, then tighten the screws and see if you can close the shade
Old 12-01-2013, 03:16 PM
hey thanks for the reply i failed to find out what is keeping the passengers tab from sliding back and forth, as a result the window is piped out just a bit but when i put the shade back on it worked fine x)
i guess thats a plus haha
Old 12-01-2013, 08:09 PM
That's definitely a plus... Lol... Glad u fixed it
Old 12-30-2013, 07:16 PM
MIflyer MIflyer is offline
Great thread - the DIY was accurate and it's an easy job. Thanks for saving me a trip to the dealer!
Kevin
Gulf Shores, AL
Old 01-04-2014, 11:35 AM
gamarosado gamarosado is offline
Mein Auto: Puerto Rico
I have a 2006 BMW 330i, the information was helpful I took of the sunroof glass but when I was going to remove shade the clips are different they don't have screws, do you know how can I remove them?
Similar Threads
Inspections / Maintenance - To DIY, or not to DIY - Inspection II instructions EPBB E46 (1999 - 2006) 119 05-09-2010 04:09 PM
Is there a DIY for fixing a broken sunroof shade? wag-zhp E46 (1999 - 2006) 11 07-21-2005 05:23 PM
2001 e46 sunroof shade guide broke sun3301 E46 (1999 - 2006) 10 06-03-2005 07:25 PM
Has the horrible sunroof cover 'clip design' been fixed on the E90? missing23 E90/E91/E92/E93 (2006 - 2013) 5 05-26-2005 01:57 PM
Sunroof problems MStewBoy 3 Series & 4 Series 5 01-23-2004 11:12 AM
