Retrofitting Parking Assist Package - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i > BMW i3 I01 (2014 - Current)
The BMW i3 and BMW i8 are the first two cars launch under BMW's new sub brand BMW i. The i3 is an all carbon fiber, all electric vehicle meant for urban mobility.
Old 05-07-2016, 03:47 AM
worelteam worelteam is offline
Mein Auto: I3
hello!
i try to add for my i3:
-reverse camera number 6653 9353705 or 6653 9396832.
-cable for rear camera 61119355946
-front active parking assistance pdc sensors number:9274429
please help with activation in e-sys
i try it but i have only add camera item in pdc screen. no image from camera.
i try to add
- reverse camera- most important for me
-front pdc sensors
-side pdc for active parking assistance without button
thank you for answer!
Old 05-07-2016, 05:13 AM
God-Follower God-Follower is offline
Moderator
Mein Auto: 2015\2016 i3s, F10 535d
How did you code the car, via FDL coding or via VO coding? I would try VO coding the vehicle and then recode the applicable modules. Should be as simple as adding ZPK to the VO and then base coding the NBT-HU, TRSVC, PMA, EPS, BDC, and SAS module.
Not sure you will get it to auto Park without adding the console button though.
Lastly, the control module for PDC is a different part number than for a car with PMA, you will probably have to replace that as well.
Old 05-14-2016, 01:08 AM
Mein Auto: I3
I try following:
connect-read fa- activate fa -reac ecu (read svt dont work) coding - done. - read coding data - edit fdl (i try all combinations for camera.) but the camera dont work...
Did I something wrong?
p.s. i would change the pma unit at last. The rear camera is now important for me.
Old 05-14-2016, 07:35 AM
Moderator
Possibly. VO coding will make all the necessary FDL changes, assuming you correctly insert the new FA value. For the i3 it should be adding the code ZPK and coding the modules I listed above, if equipped. My concern is that ZPK is also looking for a park assist button, front, and side PDC sensors to enable the auto Park feature. Might mess with it if those are not there.
Old 05-15-2016, 12:22 PM
Mein Auto: I3
hello!
I try to add word Zpk to fa/sapa element
It displays:not all elements of FA found in the Fa2fp: salpa ZPK
After that i try to code the units you listed. I have only these: acsm2,ae,body,bdc-gw,bkombi,dsc2,edme,eps,gws,hu-nbt,ihka3,lim,pma2,sme2,tbx,tcb,ucx.
Old 02-08-2017, 10:59 PM
Mein Auto: I3
Its works. But i have another problem. My 12v 20ah battery overheated. Somebody have a bdc programming parameters for charging 12v battery? I think that i code the factory values...
Sent from my Lenovo PB1-770M using Bimmerfest mobile app
Old 02-09-2017, 06:01 AM
Moderator
Hmm... Never seen anyone tinker with that yet. None of your VO changes should have affected that, were you making FDL changes in the DME/EME/EDME?
All the i3s come with the same 12V battery, so the VO changes wouldn't affect it.
Old 02-09-2017, 06:14 AM
Mein Auto: I3
There is a value for 12v charging current i have 65 and 20. Can somebody make a picture or send a file from this setting in BDC? I need check it... Thank you!
Mein Auto: I3
I dont remember the changes dme/eme
Old 02-09-2017, 06:31 AM
Moderator
Where did you locate that value, and what was the string name that you want checked?
Old 02-09-2017, 07:59 AM
Mein Auto: I3
In the bdc is battery type= value 20ah
Old 02-09-2017, 08:00 AM
Mein Auto: I3
After that is three parameters about charging current. These i need to check
Old 02-11-2017, 01:05 AM
Mein Auto: I3
Old 02-14-2017, 12:43 AM
Moderator
Hoping to check this tomorrow or the next day.
Sent from my ONE A2005 using Bimmerfest mobile app
Old 02-14-2017, 08:27 AM
Mein Auto: I3
Ok, thank you!
Old 02-18-2017, 01:54 PM
Mein Auto: I3
Hello! Did you check this parameters?
Old 02-23-2017, 03:21 PM
Moderator
Sorry it took so long, got this checked today. Mine do say 20AH in the BDC FDL that you posted. Do you need all 4 of those? I can grab a pic.
Old 02-23-2017, 11:42 PM
Mein Auto: I3
Yes, please a pic!
Old 02-24-2017, 07:31 AM
Moderator
Old 02-24-2017, 08:17 AM
Mein Auto: I3
Thank you! Do you know what is wert 64? 6,4A current? Or 0,64A?
Old 02-24-2017, 09:11 AM
Moderator
Actually, neither. Werte values are in Hexadecimal format, which means that 64 is not actually 64. If you convert it to decimal, it is 100. 50 in hex is 80 in decimal.
What this means to the car however, I do not know for certain. If you want my best guess, I would say this is the determinant for what level to maintain the 12V battery at(in terms of percent). Most BMWs maintain the battery between 65-80% state of charge so they can force a little extra juice into it during braking, allows them to recover a tiny bit of the energy and improve fuel economy(again, a tiny bit). On the i3 there is no need for that, so the operating range for the 12V battery could be bumped up to full capacity, or 80-100%.
Again, the idea of SoC limits is jus speculation.
Old 03-02-2017, 08:52 AM
Mein Auto: I3
Something is wrong. But i dont know what. After a trip , the 12v battery is charging and is hot. Produces much gas , like overcharged. I have measured from 14,5 to 14,0 Volt. It is normal?
Old 03-02-2017, 08:58 AM
Moderator
My i3 sits around 14.3 after trips, 14.8 on startup. So that seems normal. Possible you have a faulty cell inside the battery causing it to overdraw and gas out.
