Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E60 M5 (2006 - 2010)
Old 02-28-2017, 02:20 PM
EUfag EUfag is offline
Mein Auto: M5 E61
M5 E60 lag between gears
Hello first of all sorry for my english im from Czech republic. So i have a question is this lag ( delay ) between gears normal or something is wrong heres video. Thank you
Old 03-03-2017, 06:00 PM
M5Fed's Avatar
M5Fed M5Fed is offline
Retired Fed
Mein Auto: 2006 M5 E60
You could change how quickly the gear changes by hitting the button by gear shifter
Sent from my iPhone using Bimmerfest mobile app
Old 04-21-2017, 02:41 AM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
If its in the automatic mode it'll be a massive difference from manually doing it.
One thing I learned going from the e92 m3, to the e60 M5 and not having a good experience treating the SMG like an auto rather than a manual.
Fast forward to buying an STi and learning manual and now owning a V10 R8 with R-Tronic as of last week, treating it like a manual with a bit of lift and shift and always in manual mode, is a MUCH better experience than when I had my E60
Play around with manual mode, and lifting abit to shift and making sure the settings are on max.
Old 04-23-2017, 10:09 PM
nixjay5 nixjay5 is offline
Mein Auto: 2006 BMW M5
It looks like he is in the manual mode because doesn't it show an A displayed on the gauge set? It does seem rather slow if your lifting at the end it could cause the computer to trick up I think well for full speed shifting.
