Old 04-21-2017, 09:40 AM
wattbmw wattbmw is offline
Watt
Mein Auto: Black, 2000, 740i
MK what?
Sent from my iPhone using Bimmerfest mobile app
Watt
How do I know what model this unit is?
Old 04-21-2017, 09:44 AM
Drose Drose is offline
Mein Auto: driven and worked on most
Bmwsalesguy
Get me the last 7 of the vin and I got you
Old 04-21-2017, 10:00 AM
Watt
WBABR3345YEB40185
Old 04-21-2017, 10:03 AM
Bmwsalesguy
VIN: WBABR3345YEB40185
Chassis Number: EB40185
Line Make: 01 - BMW Car
Model Year: 2000
AG Model Code/Desc: BR43 - 323CI US CABRIO
NA Model Code/Desc: 0041 - 323Cic
Motor Type: M52
Exterior Color Code: 372 (Steel Blue Metallic)
Interior Trim Code: N6TT (Gray Leather)
MSRP: $42,460.00
Old 04-21-2017, 10:06 AM
Watt
Did the mk3 come in that model or the 02 year?
Old 04-21-2017, 11:46 AM
Watt
Pretty confident it is the MK3. Pulled it out of the above 323 at a you pull it here in Tampa. Cost was $25. Hope it works, but if not I can return it with in 30 days. Pray for me. BTW, thanks for the info Drose.
Old 04-22-2017, 03:53 PM
Watt
Installed the mk3 and it works. Only problem is it is version 10 and I need 22. Been online all day trying to download the software. Not good at this part. What is the cost to have the dealer update?
Old 04-22-2017, 09:15 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Easy...just type the BMW 11 digit part nbr which is plainly insight on the photo you posted (65906908529) into one of the several online part database sites like:
Q {BMW CCA Member #191509}
(SOLD)
Old 04-24-2017, 06:31 PM
Watt
Can't access GPS Nav area
Hello again,
Need help still on the upgrade.
I down loaded the v22.1 software and a KeyCD.
I used NCH Express Burn Disc Burning software to burn the image files on to a CD.
Was unable to download at any speed slower than 8x.
Installed v22.1 disc and then turned car on.
The nav ejected the disc and would no longer reload it.
The GPS Navigation label on the screen went black and could no longer be accessed.
I don't know if the nav is bad or the disc cause the problem.
I disconnected the battery and then reconnected. Turned the car on and the GPS nav screen could be accessed, but went into wait mode and eventually went black again.
What are my options at this point?
Still cannot get the disc to load.
Thanks for what ever.
Want to add that I can access the nav menu, but not the GPS navigation of the menu.
Old 04-24-2017, 06:37 PM
kooljess kooljess is offline
SOCIETY OF 7'S
Mein Auto: Sporty Shorty '01 740I
Looks like I might be getting myself an MK4....sooner than later. Will post once it''s up and running.
Old 04-25-2017, 05:44 AM
QSilver7's Avatar
Hello again,
Not sure that you're aware of this...but the MK 3 has specific shut down instructions that if NOT followed...can kill the MK 3 when disconnecting electrical power:
(SOLD)
Old 04-27-2017, 01:33 PM
Watt
Thank you for the info. I was not aware. Checked and system still works. Turned car on and everything worked. Afraid to stick disc in. Will do some more research on burner software.
